ABS delete kit??
Old Jun 22, 2012 | 02:57 PM
  #151
EvoDan2004's Avatar
Originally Posted by 94AWDcoupe
QUOTE=evodan2004=]buy the stock RS lines or build your own. here is mine.
my cars are evo 1 and evo 4. both rhd. I am gonna make my own lines.
a verbal description of how lines are plumbed would even work.
sorry i didnt know it was for an EVO 1/4. i can not help you there.
Old Jun 22, 2012 | 09:38 PM
  #152
Anarchy99's Avatar
Using a non RS stock master and eclipse proportioning/distribution block to replace the abs unit should work? Correct?
Old Jun 24, 2012 | 06:04 AM
  #153
benderrodriguez's Avatar
Use these. works great costs ~$140 for everything
Originally Posted by benderrodriguez
I'm really not sure. I probably should know that before I do things. Too late now.
And here all the P/N's with the RS Master Cylinder ( I just purchased the lancer base instead)
MR493302
MR493301
(5)MR129462
(2)MR249607
4650A046
4650A045
MR977089
Old Aug 24, 2012 | 02:56 AM
  #154
Evo_AK's Avatar
Veteran: Air Force
If I unplug the ABS in an ACD IX and just leave it unplugged, will that affect my speedo in any way?
Old Aug 24, 2012 | 02:29 PM
  #155
PCSkiBum_21's Avatar
^ no, speedo has nothing to do with the abs system.
Old Aug 24, 2012 | 04:54 PM
  #156
Evo_AK's Avatar
Veteran: Air Force
So on a IX GSR, what would the wheel speed sensors being unplugged affect exactly?
Old Aug 25, 2012 | 02:11 PM
  #157
Evo_AK's Avatar
Veteran: Air Force
And couldn't you put power (less then 5v) to each wire and use alligator clips and test where the power goes to on another wire. Then just splice those two together to bypass the ABS module?
Old Aug 27, 2012 | 01:42 AM
  #158
AFAIK.. the wheel speed sensors are what the abs ecu uses to determine if it needs to engage/disengage the abs system for each wheel individually. i do know, for sure, the rpm gauge in your cluster comes from a sensor in your transmission, i disabled and removed my abs completely and still have factory working cluster.
Old Aug 28, 2012 | 12:13 AM
  #159
Evo_AK's Avatar
Veteran: Air Force
Did you do it with or without the RS harness?
Old Oct 27, 2012 | 09:31 PM
  #160
khasal's Avatar
Thanks for the post. I have order all the parts listed and will update with my experience soon.
Old Nov 1, 2012 | 03:06 PM
  #161
sorry must have missed this. i did it without, but i did some extensive slimming down of the stock harness over last winter while i was at it...
interior harness pulled out:
unwrapped.. at this point I had already removed all of the unnecessary wiring from the driver seat to the tail lights (pile on the left) before I decided to go wild on it:
and wa-la:
engine harness on top, didn’t take out very much here. lighting, abs stuff (abs ecu on far right), and acd stuff:
done (prior to re-looming), engine and interior. only wiring for the entire car not pictured is the section running to the back of the car, just 7 more wires iirc:
I’m upset I forgot to take pictures of the whole thing completely done before I put it back in
Old Feb 3, 2013 | 07:15 AM
  #162
mrboost05's Avatar
evodan where did you buy that line from ? i have my pass side line made in that stuff it came with the ps relocation kit that buschur sells but i want more of it lol
Old Feb 3, 2013 | 07:34 AM
  #163
Evo_AK's Avatar
Veteran: Air Force
I have an BNIB STM kit for sale if anyones interested
Old Oct 29, 2013 | 05:41 AM
  #164
ItzBoosted's Avatar
Do you still have it Evo AK? I have no problem spending the $140 on that part list posted a few posts up I just want to make sure that is everything ill need to remove the ABS. What exactly comes with the STM ABS Removal kit? Will I need anything else? How come the price is so much more than those part numbers? Things just don't add up I guess, lol.
Old Oct 29, 2013 | 07:13 AM
  #165
ihockey1's Avatar
STM kit is more because they use an oem rs master cylinder, which in turn is a lot more but the same for the most part as a lancer master cylinder
