ABS delete kit??
Old Jul 23, 2011 | 09:43 AM
  #121
DaveK's Avatar
Originally Posted by milford
has anyone removed the big harness for the module...I am sick of mine just hanging in the bay. looks terrible. where do these wires go and can they be removed along with their source? or are they tied into the ecu or something?
If you're car has ACD, those wires contain the wheel speed sensors. You can go through and figure out which wire is which and then cuts & splice them together, but honestly, the easiest fix is to replace that section of harness with one from the RS model.
Dave
Old Jul 23, 2011 | 10:36 AM
  #122
Wheatley's Avatar
I removed all of mine, its fairly involved to be honest. Last year I just siliconed the connector and taped it, it wasnt very noticeable down by the cross member. This year I made a harness with a quick disconnect at the firewall to remove all unneeded wires and shorten the harness. Its all covered in my build thread.
Old Jul 23, 2011 | 04:45 PM
  #123
milford's Avatar
I do not have ACD...could i just cut that big harnesss off at the firwall where it starts to go into the rest of the harness...seal up the loose ends and call it a day?
Old Jul 24, 2011 | 01:55 PM
  #124
Wheatley's Avatar
There are wires within that harness that have 12v, If you cut that harness and it happened to touch any bare metal or grounds within the harness you could be causing yourself a very painful intermittent wiring issue. If you decide to do so just do so with caution.
Old Aug 27, 2011 | 09:07 AM
  #125
badev0's Avatar
I removed my ABS last night. I used the master cylinder off of a 2003 Base model Lancer ($35 used on ebay). I purchased all the lines with the part numbers provided in this thread ($54 shipped from Mitsubishiparts.net). I then used the diagram posted above to ground that wire on the ABS harness. All is well and the car brakes pretty good.
Do not do this mod if you race the car in a fasion that involves alot of heavy braking, the EVO abs works real well. My car does not race on a track, only a strip. You can still brake pretty intensely on the street and do what an evo is made to do
Here's a good guide on bleeding brakes: http://www.joe250.com/cars/evo8/brak...ebleeding.html
Old Aug 27, 2011 | 09:37 AM
  #126
RallyBud's Avatar
Nice job on the install. Did you run into any hiccups or was it fairly straight forward?
WRT not doing this for racing. Road courses and rally racing are huge reasons to do the ABS delete. Folks do it on road courses to give more consistent feedback in the braking zones. In rally racing it is darn near impossible to rotate the car utilizing left foot braking with the ABS still engaging.
Old Aug 27, 2011 | 10:07 AM
  #127
badev0's Avatar
Thanks bud. Very straight forward, just swap a few lines and swap the master cylinder. Very easy.
Old Oct 4, 2011 | 07:57 AM
  #128
ta ace's Avatar
did you guys pull the intake manifold when you did it? i think i might just to clean some things up and pull the firewall protector pad off it.
Old Oct 4, 2011 | 08:27 AM
  #129
badev0's Avatar
No, there's really no need to as its not in the way at all. Maybe just the strut tower bar.
Old Oct 4, 2011 | 08:56 AM
  #130
Wheatley's Avatar
This is my abs delete firewall, also removed relay plate and wiper wiring hole to the inside of the cabin. Then removed the pad, shaved the unneeded studs and resprayed the bay along with making a quick disconnect milspec harness.
This is what it looks like finished.
I had a rod bend and window the block, having all that extra wiring and unused stuff removed from the bay has made it much easier to pull the engine or anything else from the bay.
Old Oct 4, 2011 | 03:17 PM
  #131
ta ace's Avatar
I think ill start tonight... i have a jmf intake mani on mine so its kinda close but ill see what i can do i like the look of moving the relay plate!!! did you have to lengthen any wires to do that?
Old Oct 4, 2011 | 03:22 PM
  #132
Wheatley's Avatar
I had the entire harness apart to do the firewall plug, in my harness I shortened everything but in a stock harness I don't know for sure if it will reach or not.
Old Oct 4, 2011 | 07:32 PM
  #133
03whitegsr's Avatar
Looks good, where did you put the main fuse block?
Old Oct 5, 2011 | 06:56 AM
  #134
benderrodriguez's Avatar
Originally Posted by Spoolinsteve
Here is how I turned my light off after the ABS delete on an 03 evo viii
Did this work for anyone else? I can't get my light to go off.
Old Oct 5, 2011 | 09:54 AM
  #135
Wheatley's Avatar
I moved the ecu over a few inches and put it behind the glove box. My car also has srs deleted so there is a decent size space behind the glove box. The glove box is fully functional and the fuse box is easily accessible, the cover still fits.
This is a picture of test fitment before everything was bundled back together. In the pic you can see the wiper wires before they were shortened and re routed. To remove the entire harness all I have to do is disconnect power and headlight plugs and remove the entire dash bar out as one piece along with all the wiring.
This was how it looked all factory with the exception of the Alpine radio jumper harness. They are a mess without the dash in place.
