Grinding Noise, any ideas?
Good morning!
I have been noticing a "grinding noise" when driving my car at slow speeds. Up until this morning i used to think it was only when i was turning but now i am also noticing it when i am going straight. I thought it might just be because that it is an AWD car but now im not so sure. I hear it up until about 15 mph. It does get louder when i turn, and the faster i cut the wheel the louder it is as well.
I tried searching but could not find anything that really sounded like what this is. Could be a wheel bearing? Could be normal? I know its know a rock in the caliper because its been happening for a while. At highway speeds i do have a wheel bearing vibration coming from the rear of the car. The car will be going into the dealer to address that issue shortly. I am hoping at that time they can take a look at this other issue.
So, does this noise seem to be common or normal? Or is there something i should be worrying about..like a wheel falling off(
Thanks guys!
)..?Thanks guys!
Any update on this?
I'm getting the same with my car ... it only happens when turning right, but I noticed it earlier today when going straight. As far as mods goes, I have WORKS ride springs and camber plates .. could this cause a premature wheel bearing failure or possibly something worse?
Any feedback would be appreciated.
check your brakes. the inner pads wear faster than the outer. i just did mine @34k. the rears @24k. if it is a wheel bearing, it would be consistant and louder as you go faster. jack up the tires and shake the wheel left then right and see if it is loose. up and down play is usually suspension. good luck!
Now I'm hearing it sometimes when the car first fires up .. so rule out bearing .. I hear it when the car is pointed straight and moving in reverse. I have an appointment set up to get it looked at.
Are you driving without a cam cover? the one on my evo was gone when I bought it but thought it looked cool.. now mine makes a "shing" "shing" noise . I'm still trying to figure out what it is .. keep us posted
I just had a bad grinding sound too coming from my rear passenger wheel this past week. Same thing, at slow speeds and turning you hear it. Check your break pads, mine were really worn out almost to the metal. After I changed the pads it's been grind-free.
I definitely agree with Heaven's Turbo, it's most likely the brakes if it sounds like metal to metal grinding. Same thing happened to me last week.
I had my front right grind only when turning left, I pulled all the tires off and pulled all the brake pads off. The outside pads had about 1/3 meat left, but the inners were down to almost a nub. That's most likely where the grinding is coming from. I changed all my pads as the rear were almost shot too...I have 29,500 miles.
Mike
Mike
manray
Sep 17, 2016 10:47 PM
prestonlaw
Lancer Tranny/Drivetrain Tech
May 22, 2014 10:52 AM
undressesitself
Sep 9, 2012 08:48 PM
smokedmustang
37
Sep 8, 2011 12:37 PM
