Something up with my brakes?
Old Mar 4, 2004 | 08:53 AM
GrimDog's Avatar
I'll admit it i'm a bit of a car noob. Bear with me I am learning. I noticed the other day when I was on the freeway when i break I get a lot of vibration on the steering wheel like I was driving on a bumpy *** road. Is this normal do I have a break issue?
Old Mar 4, 2004 | 09:04 AM
camdog17's Avatar
How many miles on your car? My first thought, honestly, would be to take it to the stealership...several members have had problems with warped rotors, and that could be a possibility...don't take no for an answer from the dealership; I"m sure they'll first try to dismiss it as a 'non-problem'; be assertive...Good luck, keep us updated!
Old Mar 4, 2004 | 09:08 AM
GrimDog's Avatar
4k ish miles
i'm not worried about the dealer, they aren't snakey like alot I read about on here. I will call em today and try to set something up.
Old Mar 4, 2004 | 09:14 AM
Mister2zx3's Avatar
Many people have had pad material transfer from baking the pad onto the rotors. Scrubbing the rotors or replacing them fixes the symptom but doesn't cure the car. The rotors are capable of absorbing a lot of heat. If you brake more than moderately you can get a lot of energy in them. If you brake moderately and then stop the car you will end up with a lot of heat literally baking the pad onto the rotor. careful use of brakes and giving ample cool down to the calipers/rotors/pads before parking will prevent this heat from baking material onto your rotor and causing vibrations.
Old Mar 4, 2004 | 09:20 AM
GrimDog's Avatar
I break alot, i commute 80 miles a day in this car in heavy traffic.
Old Mar 4, 2004 | 01:16 PM
WestSideBilly's Avatar
El Jefe
Sounds like a warped rotor to me.
Old Mar 4, 2004 | 02:49 PM
erioshi's Avatar
Before you take it in with warped rototrs, try doing 4 or 5 fast stops from about 65 mph (in a safe area, of course). Not hard enough to trip the ABS, but hard braking.
When my Evo was pretty new I also started to get a mild shake when braking, and used this technique to clear the rotors of build-up.
Your problem may be different, but for me it was an issue with material transfer. Another thing that can lead to transfer is setting the e-brake while your brakes are still hot.
Old Mar 4, 2004 | 02:54 PM
sr20det91's Avatar
Probably build up as mentioned above. Mine did the same thing when new. It eventually wore off.
NOS1NOS2
94
Apr 23, 2011 07:07 PM
dasmyevo88
19
Feb 19, 2010 09:37 PM
detroit pistins
21
Dec 10, 2008 11:16 AM
sette3
Jul 6, 2007 04:11 AM
fbikawi
Sep 24, 2006 04:58 AM
