HBSpeed tune+CBRD BBX=FTW!
Old May 25, 2010 | 10:43 AM
  #61
scheides's Avatar
EvoM Moderator
If you're really focused on the 3000-4000 range you might want to take a look at CBRD's BBX Lite:
https://www.evolutionm.net/forums/ev...velopment.html
Looks promising, but honestly I had a BBK Full on my evo8 that didn't make 25psi until 3800rpm, and the car was plenty fast from 3000-4000 and then very powerful from there on out!
Old May 25, 2010 | 11:08 AM
  #62
mlomker's Avatar
I think he'd be putting his number goals at great risk with the Lite. On pump cams seem to help quite a bit so when you rule that out then something has to give.
Old May 25, 2010 | 11:47 AM
  #63
UT_EvoX's Avatar
Nice results on ~26-ish psi! There's a lot more to gain with this turbo on the spool-up though. I was able to get it to spool only 200-300 rpm later than stock before I threw a rod through my block (the early spool and subsequent boost spiking probably didn't help that...). I wonder how much torque and peak HP I was making holding 32 psi all the way across with 11.8 AFR + 50/50 meth. Wish I would have hit up the dyno before I ruined this engine. lol
Supraboy1
Evo X Dyno Results
21
Sep 15, 2011 03:35 PM
HB Speed
Evo X Dyno Results
23
Jun 14, 2010 09:19 AM
HB Speed
EvoX 'For Sale' Services
Apr 3, 2010 07:14 PM
HB Speed
Evo X Dyno Results
11
Feb 8, 2010 01:23 AM
HB Speed
Evo X Dyno Results
Oct 3, 2009 04:23 PM
