Anyone know how to update nav firmware?
Old Sep 14, 2011 | 05:01 AM
  #61
oztek's Avatar
Just performed this on a non-nav 2011 MR, and it worked perfectly.
Thanks!
Old Sep 20, 2011 | 01:28 PM
  #62
jimboJones's Avatar
Instructions for non-nav system WITH USB port:
  1. DO NOT PRESS BRAKES
  2. Turn audio system "OFF"
  3. Press the following in order: CH1 preset Button, |<< (seek down) button, >>| (seek up) button, and then CH4 preset button.
  4. "HFM DIAG" should be displayed on the system, if not repeat previous steps.
  5. turn the volume to 0
  6. press the "CH4" preset again to toggle through the diagnostic functions
  7. then look for any PN lower than 8785A035 or S/W lower than 0900000
  8. Once you see "HFM OK" displayed, press CH3 preset button to toggle back until "HFM DIAG"
  9. Once you see "HFM DIAG" again press "PAGE" button to enter update mode.
  10. To enter the update security code, press CH1, CH2, Ch3, Ch4 in that order
  11. and the update should start updating.
  12. once that's done press "PAGE" button to return to "HFM DIAG"
  13. turn off the ignition and remove the USB flash drive
  14. test to see if it worked.
If all of this didn't work, let me know.
PS: You don't need this update if you don't have a USB port. This update is only for compatibility with iOS 4.0 or higher through the USB port!
Hey Thanks for this, I'd like to try it soon. However I'm confused by the following steps:
What do I do when i find a PN lower than 8785A035 or S/W lower than 0900000?
Thanks in advance.
Old Sep 20, 2011 | 07:27 PM
  #63
evoch3n's Avatar
Thanks in advance.
Basically keep toggling if it's lower until you see HFM DIAG (if I remember correctly). If it's not, then you don't need the update.
Old Sep 27, 2011 | 08:50 AM
  #64
coalla2001's Avatar
no file massage
hi .
I tyy to do all off this above and when I get to "PAGE" Its write "no file" .
the usb format to fat32 and even try fat
any idea ? please ..
regards
Old Sep 30, 2011 | 10:07 PM
  #65
alfredol's Avatar
Props to evoch3n! Worked
Many thanks!
Old Sep 30, 2011 | 10:47 PM
  #66
evoch3n's Avatar
Originally Posted by coalla2001
hi .
regards
Make sure the file is not in a folder.
Old Oct 2, 2011 | 04:05 AM
  #67
coalla2001's Avatar
the file is in the root and the only file
maybe I need to change the file name or extantion ?
regards
Old Oct 2, 2011 | 12:34 PM
  #68
evoch3n's Avatar
regards
Did you extract it out of the folder?
Old Oct 3, 2011 | 02:43 AM
  #69
coalla2001's Avatar
yes .. of course.
I had need the zip file ??
i have a file name update.package
Old Oct 3, 2011 | 10:51 AM
  #70
evoch3n's Avatar
yes .. of course.
No, you just need the update.package file in the USB.
I'm not sure what you might be doing wrong since I'm not there. Try to repeat the process? Or try another USB.
Old Oct 4, 2011 | 03:49 PM
  #71
Buru_EvoX's Avatar
has anyone tried using the bluetooth with an apple device running iOS 5??
Old Oct 5, 2011 | 01:31 AM
  #72
coalla2001's Avatar
sorry being annoying ...
last time I hope I explain the process maybe I'm wrong somewhere
first - the car is Lancer Limited 2011 with Rockfor Fosgate sound system and with LINK SYSTEM withe BT
Steps :
1. Format 1 GB USB To FAT32 Quick Format ( note : I also try 2GB and even 8 GB )
2. Download the file from the link above
3. Extract to local HDD
4. Copy the file update.package to The USB
5. I Have Without NAV .
6. Insert the USB to the port
7. Start the engine ( without brakes )
8. turn Off the Sound System
9. HFM DIAG - >
10. CH4 ->->
11. CH3 Back to HFM DIAG
12. PRESS "PAGE"
13. Error Massage "No file"
More Details :
BDW : I try to format the usb also as NTFS , FAT , exFAT , FAT32 in Windows XP ( because I have Windows 7 ) .
My Fuse system Is 80000 Version
I'm despered ,
If anyone have an Ides I'll be happy to listen
Regards
Old Oct 5, 2011 | 12:51 PM
  #73
evoch3n's Avatar
Steps :
9. HFM DIAG - >
10. CH4 ->->
12. PRESS "PAGE"
More Details :
I'm despered ,
Regards
Weird, maybe it doesn't work for your country. This is only the US version. Has anyone else tested it on another country?
Old Oct 11, 2011 | 10:19 PM
  #74
kedm's Avatar
This worked flawlessly on my 2011 Evo X w/ Nav -- US.
Thanks a bunch for putting together the walkthrough!
Old Oct 14, 2011 | 04:40 PM
  #75
BeyondLimitsEvo's Avatar
I just installed a '08 nav in my non nav '11 X. Install went fine, but I can't use my Bluetooth or fuse system. I tried the USB update thing mentioned above, but when I hold set and navi, there is no option for hands free. Is there another way to update the software to enable Bluetooth and fuse, or am I out of luck because of the '08 nav?
