ECUFlash 1.40 is out!!!
Old Nov 9, 2008 | 02:36 PM
  #226
xbox4414's Avatar
LOL I think I'm just getting more confused....so say I want 26psi coming off of a stock table and stock boost, what do I do? Haha.
Old Nov 10, 2008 | 05:20 AM
  #227
Deepseadiver's Avatar
not sure if you have read this yet, but it looks like they have found some new things for the boost! If you can figure it out, explain it to me.
I am also learning as much as I can while waiting for the software to be released.
https://www.evolutionm.net/forums/sh...d.php?t=380353
Old Nov 10, 2008 | 05:38 AM
  #228
gunzo's Avatar
MrFred has told me about it .. I'll be responsible for the X equivalent .. IF I can get to be as good as he is
The X has more variables .. and I'm unable to log the changes so I'll have to go by guesswork and what he has done so far ..
Old Nov 10, 2008 | 09:37 AM
  #229
KOTT's Avatar
how soon(aprx) ecuflash, that can read/write evo x, will be released?
Old Nov 10, 2008 | 02:10 PM
  #230
dark-evo's Avatar
you can help for that and it will be faster
Old Nov 10, 2008 | 06:42 PM
  #231
xbox4414's Avatar
Is the XML in this thread earlier the latest XML or is there a newer for the USDM?
Old Nov 11, 2008 | 10:07 PM
  #232
RogueValley's Avatar
bump for clarification on xbox's question.
Old Nov 11, 2008 | 10:08 PM
  #233
Rguy's Avatar
I think everyday there is a new XML created..but asking for the new XML everyday there is a revision would really **** off the beta testers and developers.
Old Nov 11, 2008 | 10:24 PM
  #234
xbox4414's Avatar
LOL, only asked once. Haven't gone to asking everyday.
Old Nov 12, 2008 | 12:45 AM
  #235
Stormtrooper's Avatar
been running on razorlab's beta testing tune for a few days now. I don't miss my evo8 that much anymore =D
Old Nov 12, 2008 | 12:59 AM
  #236
SiC's Avatar
SiC
I wish I had people in my area with various mods to test some tunes for me. Right now I'm swapping exhausts and intakes on one car to make different tunes.
Old Nov 12, 2008 | 01:02 AM
  #237
xbox4414's Avatar
Sweet. So I'm guessing you're in the Bay Area....you coming to the hypermeet at TH?
So for those beta testing and what not....what is the max PSI the X can do with the WGDC at 100% and everything else on boost system stock? Looks like around 23psi?
Old Nov 12, 2008 | 02:15 AM
  #238
SiC's Avatar
SiC
If you only adjust the WGDC, boost correction will kick in and it'll pull your boost down. With good mivec settings and if you turn off boost correction (or adjust it correctly), you should be able to achieve 23psi up until redline (seems to drop after redline). Now I have only played around with JDM Evos so it maybe different with the USDM and the fuel you all use.
Old Nov 12, 2008 | 12:02 PM
  #239
xbox4414's Avatar
Okay well I meant with everything else like BTEL, BCLO, changed as well. What is the max boost we can pump out of the stock turbo?
Old Nov 12, 2008 | 03:23 PM
  #240
xbox, yes I'll be there on the 22nd...
