ECUFlash 1.41 released
Old Feb 1, 2009 | 08:45 PM
  #76
stokEd's Avatar
Originally Posted by nj1266
How fast is the pcmscan for logging? Is it as fast as Evoscan?
I've never used EvoScan so I really can't comment. Are looking for a sampling rate?
If it would help, I could post up a log I took the other day and you could maybe take a look at it using a trial version of PCMScan (I'm assuming it will let you.)
Can we integrate the wideband with it like Evoscan?
Here's a list of the supported PID's:
Old Feb 1, 2009 | 08:48 PM
  #77
SiC's Avatar
SiC
Does the software work with the Tactrix 2.0 cable w/o any other hardware? Do I need to buy any hardware with their software license to get the full version?
Thanks
The Tactrix 2.0 cable works without any other hardware.
Old Feb 1, 2009 | 08:54 PM
  #78
stokEd's Avatar
Thanks
I'm using an OP 2.0 cable, so yes.
Old Feb 1, 2009 | 08:59 PM
  #79
stokEd's Avatar
Realized my reply wasn't as helpful as it could have been...
I'm looking at the list of PIDs and it shows listings for the AEM, Innovate LM-1, TechEdge, and Zeitronix wide bands.
Old Feb 1, 2009 | 10:43 PM
  #80
HB Speed's Avatar
I have been using this
the logger is a bit slow and really doesn't support many PID for evo X
it "gets the job done"
Old Feb 2, 2009 | 05:36 AM
  #81
honda-guy's Avatar
How fast is the pcmscan for logging? Is it as fast as Evoscan? Can we integrate the wideband with it like Evoscan?
i use the Innovate OpenTune OBD-II / CAN Interface OT-1. it has it's own obd2 port cable and works on most if not all odb2 cars. i use the OT-1 along with the Innovate LC-1 and Logworks (which is free from Innovate). sample rate for the Evo X is very fast.
http://www.innovatemotorsports.com/products/ot1.php
Old Feb 2, 2009 | 07:02 AM
  #82
bobik's Avatar
I have a little problem with 1.41 on a JDM EVO X with this ROM 52350016 , I was able to read ECU one time , file looks OK, but couldnt write it (sending init........no response for any known code), after this I cant read file again the same error, Openport works OK in EVO 9, drivers reinstaled, everything looks OK, any ideas ?
Old Feb 2, 2009 | 09:13 AM
  #83
Colin's Avatar
Have you tried with fresh install of windows or with other laptop that never had ecuflash/evoscan installed?
Old Feb 2, 2009 | 02:27 PM
  #84
burnings's Avatar
I am using the same ROM but does not encounter this problem. Tried on 2 Evo X and still ok! The only time I encountered error is after I loaded a Rom I need to off and on the ignition in order for the flash to be successful.
Old Feb 2, 2009 | 02:38 PM
  #85
AIK's Avatar
AIK
Help pls with xml-files. I have 3 EvoX roms (hex-files)
-EDM GSR 5MT ID 53040007
-RS 5MT ID 53040007
-EDM GSR SST ID 53050006.
I tried to create xml from other xml-files, which are at the ''rommerdata" directory, but don't receive correct result.
I can sent mail with my hex-files if it is necessary.
Old Feb 2, 2009 | 02:49 PM
  #86
KOTT's Avatar
-RS 5MT ID 53040007
Gunzo already working on it
Old Feb 2, 2009 | 07:18 PM
  #87
DRAG's Avatar
Interesting. So you can use your Logworks data in Data Log Lab? Are you able to log knock?
Old Feb 2, 2009 | 08:27 PM
  #88
GST Motorsports's Avatar
OT-1 is generic OBD2, just like PCMscan
My OT-1 is a door stop that has never worked correctly, YMMV.
PCMscan is $50 cheaper and less hardware to use (OpenPort 2.0 works with it)
Old Feb 2, 2009 | 09:33 PM
  #89
PR_Mivec's Avatar
wut version of pscmscan are you guys using? i cant make mine work for the evo....
Old Feb 2, 2009 | 11:41 PM
  #90
SiC's Avatar
SiC
PCMScan v2.4.10 (Build 977)
