The PCMScan Thread
Old Feb 26, 2009 | 02:38 PM
  #31
jason4656's Avatar
yeah i changed the config for elm, i read earlier where you had suggested to someone else who was having problems, just not sure if the elm limits the abs load max.
I have just got the new version and installed that, i cannot find anything that limits abs load so im confused why it was capped at 159% thats all
i will try again tomorrow cos its late now without that config file but all i am gonna do is tick and untick the same boxes so dont see how its gonna be that, ill try with the open port 2.0 tomorrow
quite good logs, shame about the knock or it would be perfect
is there not a way to manually configure it?
Old Feb 27, 2009 | 01:10 AM
  #32
verkion's Avatar
Anyone try the dyno yet? I keep trying to do 4th gear pulls but it only seems to plot to about 2K RPM no matter how high/how much past this I go. :-P I'm sure its not the most accurate way to calculate HP/Torque, but, *shrug*. I wanted to compare stock map and the flashed map...that's all.
Old Mar 1, 2009 | 07:53 PM
  #33
gunzo's Avatar
How do I send the PID requests ??
I'm starting to play around with the PCMScan now and modifying the OBD output
Old Mar 3, 2009 | 02:50 PM
  #34
verkion's Avatar
Settings tab > PID Config? That'll let you select which PID to monitor...there's also OBD II Terminal under tools which you'll probably like using ;-) Let's you send commands "directly".
On a completely separate note...has anyone played with making their own dashboards yet? I just started in on a "replica" EVO-X dash the other day...but instead of displaying all the fuel mileage and stuff in the center, I'd put boost and whatever else in the center. Its kind of ugly so far...so give me a week or two to clean it up and then I'll post the customized "dashboard".
verkion
Old Mar 4, 2009 | 07:29 AM
  #35
aiden1983's Avatar
Do you buy just the software or do u buy the interface also? I am looking into getting this but am unsure what I need to buy.
Old Mar 4, 2009 | 01:33 PM
  #36
SiC's Avatar
SiC
If you have the OpenPort cable, you do not need to buy it with the interface.
Old Mar 4, 2009 | 03:25 PM
  #37
aiden1983's Avatar
Does the LC-1 hook up to ur computer via usb? Also (I am sure I can just look this up but....) does the PCMScan work with OSX?
Old Mar 5, 2009 | 12:26 AM
  #38
zTargeTz's Avatar
i belive the LC-1 is serial, but you can get serial to usb converters (not sure with macs)
Old Mar 7, 2009 | 05:56 AM
  #39
gunzo's Avatar
Fullboost loggin anyone ??
Old Mar 7, 2009 | 11:00 AM
  #40
TTP Engineering's Avatar
We are lucky to have OBD-II scanning on our Mustang Dyno.
Old Mar 7, 2009 | 06:18 PM
  #41
gunzo's Avatar
ok guys .. initial test going out for logging the full boost parameters .. fingers crossed !!
My calculations say yes I'm good
but I can't fix JDM yet ..
Old Mar 7, 2009 | 10:54 PM
  #42
stokEd's Avatar
And the result? And what are the 'full boost parameters'?
Old Mar 8, 2009 | 12:15 AM
  #43
verkion's Avatar
He means...uncapped (no 1.55Bar/22-23PSI capping) when logging...I'm going to test this tomorrow morning as well. LOL.
verkion
Old Mar 8, 2009 | 04:24 PM
  #44
stokEd's Avatar
verkion
Ah, okay, that's what I thought. Mind sharing what your doing? PM me if you could. Thanks.
Old Mar 8, 2009 | 05:32 PM
  #45
nj1266's Avatar
Anyone figure out how to log higher than 22.xx pek boost with this software?
