The PCMScan Thread
Old Mar 8, 2009 | 06:28 PM
  #46
gunzo's Avatar
Originally Posted by stokEd
And the result? And what are the 'full boost parameters'?
Not as good as I thought I was
Verkion is testing some parameters for me .. since I don't have USDM to test with ..
Old Mar 8, 2009 | 09:53 PM
  #47
verkion's Avatar
Still working on it/testing with gunzo....grrrrr
Old Mar 8, 2009 | 11:25 PM
  #48
nj1266's Avatar
So the uncapped boost maps that Gunzo posted on the Evo X forum did not work out?
Keep us posted and thanks for testing.
Why would Mitsu cap the boost on a 3 bar map sensor
Old Mar 13, 2009 | 04:26 AM
  #49
jason4656's Avatar
i still have not managed to get mine to log past 159% load, i have looked through everything and even reinstalled the latest version of pcmscan, but like i said i was using elm and i am not sure if that restricts it, next time i get a chance i will try with op2 rather than elm protocol
Old Mar 13, 2009 | 08:16 AM
  #50
gunzo's Avatar
its not the PCMScan .. its your ecu ..
find a FQ360 and you should be able to log beyond 159% ..
Old Mar 13, 2009 | 10:35 AM
  #51
jason4656's Avatar
what do you mean? the jdm car wont let you log past 159% load? the guy who started the thread was in japan, im sure he didnt have an fq and it was working ok apparently?
Old Mar 18, 2009 | 04:11 PM
  #52
burnings's Avatar
Anyone knows what is the Pid for LTFT Low and LTFT Mid in PCMSCan?
Old Mar 18, 2009 | 04:23 PM
  #53
SiC's Avatar
SiC
I don't think there is a low and mid, it's just STFT or LTFT.
Old Mar 20, 2009 | 07:14 AM
  #54
burnings's Avatar
I realised that the PCMSCan does not validate all available PIDs even on slow or fast scan. Is there a complete listing somewhere that we can download and input the PID manually?
Old Mar 20, 2009 | 03:26 PM
  #55
burnings's Avatar
If we cannot log past 159.9, how do we know which cells to edit?
Old Mar 20, 2009 | 03:38 PM
  #56
GST Motorsports's Avatar
Is this a difference between USDM and non-USDM Evo 10's? I can log uncapped load just fine. Which load PID are you logging?
Old Mar 20, 2009 | 06:26 PM
  #57
SiC's Avatar
SiC
JDM is not capped, I really don't know why some have these issues.
Old Mar 21, 2009 | 02:55 PM
  #58
burnings's Avatar
Sae.load_abs
Old Mar 21, 2009 | 05:20 PM
  #59
Piper747's Avatar
Could anyone clue me in on how absolute load percentage converts into actual boost? I am using PCMscan to log. My peak boost appears to be around 195%. Also, how can you view log graphs from different logs side by side to compare. Yes, I am a Newbie. Any help would be great.
Old Mar 22, 2009 | 02:15 AM
  #60
burnings's Avatar
LOAD_ABS = [air mass (g)/intake stroke] / [maximum air mass (g)/intake stroke at WOT@STP at 100% volumetric efficiency]* 100%.
Why you need to convert to actual boost when you can read it off the ecu... ??
