The PCMScan Thread
Old Feb 18, 2009 | 06:15 PM
stokEd's Avatar
The PCMScan Thread
Hey guys,
I'm starting this thread so we can consolidate all the discussion regarding logging with PCMScan on the Evo X.
Questions, comments, logs, etc. encouraged!
More to come...
Eddie
Old Feb 18, 2009 | 08:19 PM
SiC's Avatar
SiC
For those of you having problems with the PCMScan configuration, you are all free to use my configuration file located here.
sic.cfg
BTW, all my settings are in metric so you'll have to change those settings if you want PSI. Also my config file is setup for an AEM WB on COM5, change that setting as necessary.
Old Feb 20, 2009 | 05:24 AM
Guru's Avatar
Does it log calculated load?
Old Feb 20, 2009 | 11:33 PM
verkion's Avatar
Hrm still having that weird problem with the MAF readings being low resulting in negative boost pressure when calculated using the script. The CURVES look ok...but not the actual measurements. I'd like to get it working for obvious reasons :-P Oh, that's using your config file too SiC, so it must not be that. Anyone also have the same problem and manage to solve it?
Thanks!
verkion
Old Feb 20, 2009 | 11:54 PM
SiC's Avatar
SiC
Thanks!
verkion
You're not talking about idle & cruise boost pressure are you?
Old Feb 21, 2009 | 10:37 AM
stokEd's Avatar
Yes. I'm leaving to makes some logs () now.
Old Feb 21, 2009 | 05:50 PM
verkion's Avatar
Hrm...I dunno what I did but Boost is now showing properly...i.e. PSI etc. Funny though...I'm beginning to wonder if the CDN X MAP sensor is only good to 1.55bar...
verkion
Old Feb 21, 2009 | 06:00 PM
SiC's Avatar
SiC
verkion
No, all the MAPs only show up to 1.55 bar on PCMScan.
Old Feb 22, 2009 | 04:46 PM
verkion's Avatar
Yeah, good to know. Gunzo let me know that too. Limitation of OBD port protocols? Ah well, doesn't matter. I'm going to try building a boost gauge. LOL. :-P
Old Feb 26, 2009 | 02:51 AM
jason4656's Avatar
Hi guys,
SIC what is your calculated load as a percentage worked out at? in your config file? i went out to try it last night however wasnt sure how you had configured it
thanks
Old Feb 26, 2009 | 04:08 AM
SiC's Avatar
SiC
Originally Posted by jason4656
Hi guys,
thanks
No adjustments needed, it's just a PID for Absolute Load. Check my config file posted above. If you compare your maps to your log, the load numbers should be really close, if not exact.
Old Feb 26, 2009 | 04:57 AM
hameedosh's Avatar
i just downloaded the pcmscan 2.4 (demo) but it cant read my ecu???
am i missing some thing or should i purchase the full version ???
Old Feb 26, 2009 | 05:03 AM
SiC's Avatar
SiC
Your setting must be wrong.......
Open PCMScan, click on the Settings tab and click OBDII Settings. Go down to OBDII Connections Settings and under OBDII Interface > Interface Type select J2534
Old Feb 26, 2009 | 05:42 AM
jason4656's Avatar
hi, but the absolute load is calculated in a % so what relevance is it to the kpa load of the map?
for example if 50% = ? load?
thanks
edited to add, i was asking about your config file thats the one i used
Old Feb 26, 2009 | 05:52 AM
SiC's Avatar
SiC
thanks
Load on the maps are percentages (10-320%)..... if yours says kpa then your xml file must be bad.
