TephraMODs for the X
Old Feb 13, 2010 | 09:24 AM
  #91
LaXGSR's Avatar
Can't wait for KnockCEL! Can the CEL also be used to warn us of dangerously lean conditions (for those without a permanent wideband)? I know the stock narrowband is not accurate at all, but does it still read during WOT? For example, if it still reads stoich at WOT then you probably have an issue. Thanks tephra!!
Old Feb 13, 2010 | 09:47 AM
  #92
Mellon Racing's Avatar
Originally Posted by Golden
It could be a percent cut, or a taper off. An instant cut to 75% throttle wouldn't affect too much, but should stop the knock and save the engine.
I'm concerned about passing someone and getting throttle cut
Old Feb 13, 2010 | 10:54 AM
  #93
Hiboost's Avatar
I think if you can adjust what percentage to cut throttle down to this wouldn't be that major of an issue. Granted when you really need to have your full expected speed to complete a pass you don't want the car falling on it's face at the wrong moment, then again if the car is knocking badly you also don't want to pass at all costs including grenading the engine.
When I was testing using TPS limiting to elminate 5th gear compressor surge I found that it was really easy to adjust all 4 tables and set the max TPS that was available on the charts. If we could figure out which of the 4 tables are used we may be able to re-direct a couple to a single map and then designate one for valet mode where TPS is limited to 30-40% max and/or a moderate engine knock mode where 7+ counts of knock triggers the TPS to be limited to whatever ends up helping enough to reduce knock without cutting TPS completely. Basically it would automatically let off the gas partially and you would still have decent acceleration with about 20 psi and be much less likely to knock.
Old Feb 13, 2010 | 10:59 AM
  #94
has the effectiveness of reducing throttle to counter knock been tested already? how much is needed?
Old Feb 14, 2010 | 09:21 AM
  #95
Clipse3GT's Avatar
I think setting the knockCEL to limit/knock cut off to turn on only when past like 60% throttle would be crucial since the 4b11 knocks at lower RPMS, especially with harder motor mounts and stiffer suspensions and clutches.
Old Feb 14, 2010 | 12:49 PM
  #96
migs647's Avatar
Post in wrong thread.
Old Feb 14, 2010 | 01:29 PM
  #97
xPRimNT's Avatar
Thanks for the hard work Tephra, I know I'm pretty excited for KnockCEL and AltMaps!
Old Feb 14, 2010 | 03:54 PM
  #98
tephra's Avatar
well the knockcel would be independent of the throttle cut.
obviously both would have thresholds so it doesn't kick in unnecessarily.
I am still experimenting with 2 levels of knockcel on the X - not sure if its working 100% yet... might be a problem with CAN communications...
Old Feb 15, 2010 | 05:47 PM
  #99
xPRimNT's Avatar
^ Let me know if you need anything tested!
Old Feb 15, 2010 | 07:22 PM
  #100
tephra's Avatar
sure thing.
Old Feb 15, 2010 | 07:46 PM
  #101
tsitalon1's Avatar
Thephra, what is the reasonable timetable before we see JUST the KnockCEL available? The TPS cut would be Icing, but not needed right away.
Old Feb 15, 2010 | 07:48 PM
  #102
tephra's Avatar
I havn't decided how I am going to package it yet...
depends on the level of interest I guess
Old Feb 15, 2010 | 08:10 PM
  #103
migs647's Avatar
High level ... I'll donate as soon as you do
Old Feb 16, 2010 | 04:14 AM
  #104
Guru's Avatar
I'm in for donation too
Old Feb 16, 2010 | 08:19 AM
  #105
tsitalon1's Avatar
Me too!
