ECUflash "ECU options" What do they do?
Old Jul 9, 2009 | 08:10 PM
Ray Knight's Avatar
Question ECUflash "ECU options" What do they do?
Does anyone know what these do? Just looking at my old tune compared to my new tune where my SS-T is now acting crazy, there are some differences i can see in the "ecu options"
ECU options Set #2 Bit.1 shows 1 on my old tune, and 0 on my new tune.
ECU options set#4 Bit.1 shows 1 on my old tune and 0 on my new tune.
Does this affect anything? Could it cause a "service required" light and some kind of bad comunication between the ECU and SS-T controller?
Still trying to figure this thing out... My car is still hardly drivable with the SS-T acting like this
Old Jul 9, 2009 | 08:24 PM
tephra's Avatar
ECU_OPTIONS_2 bit1 (ie second last bit) is rear02 disable/enable
1 = enabled
0 = disabled
so that will stop rear02 related CEL's, but hopefully you have removed your rear02 so that it doesn't get screwed up (because the heater also gets disabled)
ECU_OPTIONS_4 bit1 I don't know about - yet :P
Are there any DTC's? if so what codes?
Old Jul 9, 2009 | 08:30 PM
Ray Knight's Avatar
1 = enabled
0 = disabled
Test pipe is installed, O2 is still in place. so i should just put a cap in the O2 bung and unplug the sensor?
I am getting P1870, P1871, and P0725.
Old Jul 9, 2009 | 10:24 PM
tephra's Avatar
P1870 = engine torque signal abnormality..........
P1871 = aps system (signal abnormality)............
P0725 = engine speed signal abnormality...........
I would say fix the torque limiter tables so you dont get P1870 and then see if 1871/0725 go away
Old Jul 9, 2009 | 10:58 PM
Ray Knight's Avatar
Is it possible they will just go away? I cannot clear the P0725 with PCMscan. It's always there. If we get the torque limiter tables right it should clear it? I am driving super light and off boost to avoid the tranny going crazy not knowing what to do. I am not putting any torque to the car at all. How can i get the code clear? The tranny is either in some kind of limp mode, or not comunicating with the ECU.
Old Jul 9, 2009 | 11:01 PM
tephra's Avatar
worry about what you CAN fix now, and then worry about the other remaining stuff later (if its still there)
fix the torque maps.
Limp mode for SST = 1/3/5 gears only - so that's why its driving funny
Old Jul 9, 2009 | 11:07 PM
Ray Knight's Avatar
I can shift into any gear. in auto mode, it revs to the moon between shifts, in manual mode, on the gas shifting, it does the same like in auto mode, when off the gas when shifting it slams into gear like shifting a manual without pressing the clutch. Also it is simulating slip. When you touch the gas pedal it slips about 600rpm then engages. Once the little slip is done it hold power like normal.
Working on the torque maps
Old Jul 9, 2009 | 11:10 PM
tephra's Avatar
hrmmm - well fix the 1870 code first (tq maps)
then see what other codes you get...
you might be better to go back to the stock ROM and then start tuning again - obviously something wayward has happened along the way
see how the tqmap fix goes
Old Sep 1, 2009 | 10:57 AM
Koroshiya's Avatar
I'm getting U0100, P1870, & P1871...
I'm not getting the other code you got. What did you do to fix this?
I already have the spacer on my rear o2. (It's the elbow style)
Sent an email to my tuner to see what he has to say! Also directed him to this post.
Old Sep 1, 2009 | 12:31 PM
Q15H's Avatar
I got those codes on my MR after flashing a map. Only from the flash - clear them and they never come back.
Old Nov 19, 2009 | 06:56 AM
LVSBB6's Avatar
I was getting the same U0100, P1870 and P1871 and SST only had 2/4/6th gears. What did you guys end up doing to resolve the issue?
Old Nov 19, 2009 | 08:34 AM
Hiboost's Avatar
Hopefully everyone has a saved "original rom" for their car somewhere. Best bet is to go back to the original rom and then save a copy and start pasting in your basic tables such as High/Low Octane Fuel and Timing as well as injector tables if those are different from stock. The next tables you may have to work on are the Airflow and Torque limits tables which can set off codes if expected load is too low or too high for any given TPS. Then and you can import other tables if they are different one at a time to see where things start to go badly. Once you establish what triggers the codes you can rework those tables properly and that should resolve your issues.
Fast_Freddie
Oct 30, 2023 01:56 AM
evoscan
52
Jun 20, 2017 01:46 AM
Honto
Sep 8, 2012 06:29 PM
crimson red
12
Sep 18, 2010 06:36 AM
tsitalon1
29
Sep 14, 2010 07:33 PM
