FIC 1100's Experience?
Old Nov 7, 2011 | 01:58 AM
  #166
KOOLER's Avatar
Right now I use TRAVMAN's latencies and 1125 scaling with LTFT LOW of -5% and LTFL MID is 0% and does not want to update for a while...
There was indeed a HUGE vacuum leak under MAP sensor (seal was damaged).
Isn't 1125 is TOO high for 1100 cc injectors?
Originally Posted by fostytou
Are you sure you reconnected all pipes, the MAF, the FPR line, and didn't squeeze one of the injector bushings on the edge of its seat in the intake manifold? Sounds like an air leak.
Old Nov 7, 2011 | 05:55 PM
  #167
UT_EvoX's Avatar
1125 scaling is way too high for these guys. My scaling on 91 octane is somewhere in the 900-something range.
Old Dec 28, 2011 | 07:23 AM
  #168
VGergo's Avatar
with Buschurracing double pumper and FIC 1100 E85, stroker engine and FP green turbo would be enough for ~500 whp ?
Old Dec 28, 2011 | 08:50 AM
  #169
mrfred's Avatar
Definitely, but not much more than that. 525 whp was the limit (just shy of going static) on an FP Red Evo 10 with a BR double pumper that I tuned. An Evo 8/9 might be able to squeak out a little more.
Old Dec 29, 2011 | 03:17 AM
  #170
VGergo's Avatar
Thanks, and it was on mustang dyno or virtual dyno in dynojet mode ? The X was 2.0 ? The next step maybe FIC 1250 with Double pump but is low impedance .
Also thinking on to get set of FIC 1680 with single DW300 . The car have to work well on pump gas and E85 too .
Old Dec 29, 2011 | 05:15 AM
  #171
tephra's Avatar
1680's are only good on E85... they dont work for pump..
Old Dec 29, 2011 | 08:51 AM
  #172
mrfred's Avatar
DynoJet, 2L motor. For a given turbo and injector, a stroker can make even more power than a 2L because peak power will be shifted to lower rpm where the injector has more time to inject the needed amount of fuel.
Old Dec 29, 2011 | 12:48 PM
  #173
scheides's Avatar
EvoM Moderator
I humbly disagree. Maybe I just got lucky, but I have been running my 1680's on pump for a few weeks now with great results. Cold, warm, and hot start are dandy and they drive great. That being said I do not seem to have the issues with them that others have reported....
Old Jan 2, 2012 | 03:30 PM
  #174
Beeble's Avatar
FWIW with a wally 400 pump i had to scale my 1100s high like this aswell. fuel pressure just goes through the roof. latencies adjusted for idle/cruise to make it all happy.
Old Feb 10, 2012 | 02:04 PM
  #175
KOOLER's Avatar
I run DW 300 pump...
Can you share your final scaling / latencies for FIC1100 and LTFT values you've got settled? THANK YOU!
buzzzin_IX
Jun 6, 2016 12:31 PM
onyx1121
Jan 25, 2016 02:25 PM
auffy16
Jun 24, 2015 01:36 PM
mrfred
May 10, 2012 12:26 PM
porsherules911
Nov 4, 2011 10:51 AM
