EvoScan 2.8 wont log using my 2.0 Tactrix cable
Old Nov 28, 2010 | 05:19 PM
HR2L's Avatar
Long story short I keep getting this every time I try to begin :
- Error: OpenPort2 USB Cable Not Responding. Unplug your USB cable from the PC and replug this in and retry.
I do exactly what it says, and unplug the tactrix cable from my PC and reconnect it, yet with no success. I checked my driver settings for my tactrix cable when its plugged in via USB and it recognizes it just fine. Also I am able to pull my map, clear DTC's, write to ECU with ECUFlash which is why it is baffling me so much. I have read/searched around and noticed evo 8, 9 guys had issues similar to this but it was nothing more then they needed to switch from 2.0 to 1.3. I however should be using 2.0 and am still having issues.
Anyone? Please, I really need to do some data logging so i can make adjustments to my WGDC due to overboosting issues.
Just a side note, I'm using Windows Vista Home x64bit and my computer is up to date in terms of windows update related updates (.net framework updates as well).
Old Nov 28, 2010 | 07:15 PM
tehSteve's Avatar
as much as I hate to say it... you probably wanna downgrade to xp 32bit.
i have a netbook for loggin personally
or you can try compatability mode, uac turned off, and sett the setting to like windows xp sp2
Old Nov 28, 2010 | 09:38 PM
HR2L's Avatar
I was able to get it to run in compatability mode as well as running it as admin. Thanks for the advice!
Old Nov 29, 2010 | 12:53 AM
tehSteve's Avatar
woot. no problem!
Mitsu.kid.02
Lancer Engine Management / Tuning Forums
217
May 25, 2016 10:47 AM
SlickDude
Mar 11, 2016 04:37 PM
CDrinkH2O
13
Apr 28, 2014 08:08 AM
monkeyevo
Jul 20, 2011 11:09 PM
warrusmc
Jul 28, 2010 02:32 PM
