Warming up engine
Old Feb 14, 2013 | 01:16 PM
  #31
mshilto89's Avatar
Originally Posted by Drkramm
I'm not sure I would call what the Mr has launch control ... More like a two step ... Just because we find a use for it in other ways doesn't mean it was expressly made for that reason ...
I'm not saying to wait till your motor is warm and then beat the **** out of all the cold drive line parts ... Hell I can barely shift till the tranny is warmed up when its 10 degrees outside
THIS x's 1000000. I can't wait for warm weather....
Old Feb 15, 2013 | 03:14 AM
  #32
Fede's Avatar
The reason is as said before: oil pressure.
I'd like to think about it as for the alternator. It can't provide the same voltage thru the whole rpm range, so does the oil pump with pressure.
Anyone can do what thinks is best, I put out my point of view.
In addition to my experience, if you want to thrust, I can't find the right issue but it was well explained inside Race Engine Technology article.
For give you an example, the conclusion for camshaft was that most of the wear on it was generated during idle operation... that is only a small fraction of total time spent by the engine thru the rpm range.
Sorry for my English, hope everyone can understand.
Old Feb 15, 2013 | 03:17 AM
  #33
Fede's Avatar
Originally Posted by Kracka
More components besides just the engine need to be warmed up. The most effective and efficient way to warm up the car (engine, transmission, drivetrain) is gentle low-load driving. My house is located 1.5 miles off the highway I take to work which gives my car ample time to come up to full operating temperature.
Totally agree
Old Feb 15, 2013 | 08:33 AM
  #34
vegittoss15's Avatar
Right and nobody is disagreeing with you, but to start driving after 15 seconds of startup? That seems a little nuts to me. And I still don't buy that idling is bad for your engine (unless you're somehow overheating at idle...)
Old Feb 15, 2013 | 09:12 AM
  #35
Kracka's Avatar
Idling isn't bad, there are just more efficient and effective ways to warm up an engine.
Old Feb 15, 2013 | 09:31 AM
  #36
I'm not disagreeing with that. But Fede seemed to indicate that in an earlier post (idling being the worst thing for your car)
Old Feb 15, 2013 | 12:32 PM
  #37
opticfilms24p's Avatar
I warm up my for 10 to 20 seconds every day and my evo x has 72,000 miles and I have not had a problem like yours. But I do live in California its 75-95 degrees for 9 months out of the year. Good luck with your problem
Old Feb 15, 2013 | 04:12 PM
  #38
richardjh's Avatar
Originally Posted by fostytou
If nothing else your WGA spring hasn't warmed up yet
You could probably count on one hand the number of people thinking about their WGA spring temperature when driving.
fosty, you operate at a whole other level, man!
Rich
Old Feb 16, 2013 | 12:09 PM
  #39
love9sick's Avatar
Nonsense, you can idle warm up your car. When you crank the motor and start it the engine revs up to around 2k rpm and slowly drops to idle 900rpm over time as it warms up so no oil pressure or other issues are to be worried about. The suspension and transmission will still be cold so I don't recommend going WOT right away.
I said it before, it's the P0420.
Old Feb 16, 2013 | 05:21 PM
  #40
way2low01's Avatar
Where in the manual does it state to wait until one bar is shown before driving? All I can find is where it states to drive the car slowly to allow the drivetrain fluids time to warm up before going ***** to the wall. Can someone provide the page number so I can reference it? In any case, I let it idle for 20 to 30 seconds, then take it easy for atleast 5-10 minutes after the coolant temp has reached its operating temperature.
Old Feb 17, 2013 | 04:03 PM
  #41
love9sick's Avatar
It's not in the manual, you don't have to. You'll be fine if you drive it with out WOT high revs but it's a rule of thumb for turbo cars. Just like people may tell you after hard driving your car to let it idle a minute or two before you shut it off on turbo cars.
Old Feb 18, 2013 | 12:35 AM
  #42
Fede's Avatar
Hi guys!
I wasn't saying that idling is the worst thing for the car! Going to 7000 rpm with the engine cold is certainly worst than idling!
What I was trying to say is that for engine lubrication, the worst condition is idling. So to warm up the engine sooner and better I suggest to start the car, wait 10-15-30 sec and than drive it with care (avoid high rpm and boost) until 5-8 miles.
Old Feb 18, 2013 | 06:07 AM
  #43
iirc, it is in the manual. I'll get you guys a page number tonight when I get home if possible
Edit:
Can't seem to find it at the moment, but if I run across it again, I'll be sure to post here.
BoosTyEVO
Mar 5, 2023 08:42 AM
orangeorphan
16
Jun 23, 2015 12:07 PM
Hotsauce101
May 14, 2015 09:50 PM
evo8lane
Dec 9, 2014 11:00 AM
RawrImAMonster
15
Oct 19, 2013 01:51 PM
