View Poll Results: Which best describes your oil when you wipe the dipstick on a napkin?
It's dark after less than 1000 miles and it smells like fuel.
119
56.13%
It's maybe a little dark, but I don't really smell fuel.
65
30.66%
Clean as a whistle
28
13.21%
Voters: 212. You may not vote on this poll
Fuel dilution in oil problem
Old Dec 25, 2008 | 12:53 PM
  #76
Spookpur's Avatar
Could be blow-by? Piston rings may be worn, what year/mods are on your car? Did you check the oil after the car warmed up or before? Oil level should not be at full mark if it was cold or not run very long. Is the oil "thin" or "normal"?
Old Dec 25, 2008 | 12:58 PM
  #77
fryedchikin's Avatar
All Evo's run very rich on the stock tune, which will contribute to gas contamination of the oi. But it seems to be even more of an issue with the X. I have seen several other threads discussing this issue.
Old Dec 25, 2008 | 01:00 PM
  #78
Spookpur's Avatar
Ahhh, yes, didn't even notice this was posted in the X forums. From what I've read, the X's run richer than the VIII's and IX's did, so that would make sense.
Old Dec 25, 2008 | 06:18 PM
  #79
element2zz's Avatar
2008 evo x
K&N cone air filter, test pipe, cat back exhaust - no muffler
Old Dec 25, 2008 | 06:42 PM
  #80
element2zz's Avatar
Originally Posted by gsr0801
I had that problem and found out that one of my injector was leaking.
your injector was leaking?? did the dealer find that??
and what were your symtoms ??
Old Dec 25, 2008 | 07:05 PM
  #81
NMX's Avatar
NMX
You should probably check this thread with others having the same issue.
https://www.evolutionm.net/forums/ev...l-problem.html
I might get my oil analyzed soon because I smell a hint of gas too, but I'm not sure it's really anything to worry about.
Old Dec 25, 2008 | 07:06 PM
  #82
NMX's Avatar
NMX
My oil seems to have a hint of gas smell in it too. Weird thing is, it seems more noticeable when the car has been driven and the oil is hot. When I first checked it in the morning, it wasn't so noticeable. If it is fuel, maybe it's because the fuel separates from the oil when sitting overnight in the car? Anyways, I'm thinking of getting my oil analyzed, but I'm about to change it and only have 1500 miles on the current oil (but it's been in the car 3 months). Will this be too little mileage to give useful results from oil analysis?
Old Dec 25, 2008 | 09:56 PM
  #83
Papi4baby's Avatar
Originally Posted by gizmotoy
I know nothing about oil analysis, but this seems straightforward. 20,000 is 2% of a million.
i r stupid
Old Dec 25, 2008 | 10:05 PM
  #84
element2zz's Avatar
i just checked my oil today after a cyn run
oil is dark and reeks of gas!
700 miles since last oil change with royal purple...
either needs to come out with another reflash or the accessport is in my very near future.
Old Dec 26, 2008 | 09:18 AM
  #85
scottatyamaha's Avatar
For now until we know how serious the fuel dilution in oil is keep your oil changed at 3k miles intervals instead of what the book says at 5k.
Old Dec 26, 2008 | 11:06 AM
  #86
burt_reynolds's Avatar
I've got about 1600 miles on my latest change (Pennzoil Platinum 5W-30), and my dipstick smells of gasoline. My car's completely stock, but I drive it fairly hard. It's an *evo* for christsake, so I'm assuming it's supposed to be driven hard.
Can't wait to see those oil analysis results.
I really want the Cobb AP, but I don't have $700 to blow on my car right now. I was wondering if maybe a drop-in panel air filter would help here? I've heard that the drop in filters lean out the AFR 0.5-1.0 point. That seems substantial. I was wondering if that's enough to help here? Anyone with a panel filter smell gas in their oil?
EDIT: It just occurred to me that if there's really *that* much gas in the oil for so many drivers, then these cars, in stock form, are probably going to start using quite a bit of oil over time as the cylinder walls wear prematurely. Anyone with > 10k miles seeing an increase in oil use? I've got 6600 on my car, and the level's not dropping at all.
Old Dec 26, 2008 | 11:16 AM
  #87
STi2EvoX's Avatar
Well, I'm the OP who started this thread, and I've had a drop in filter all along, so there's your answer. Although I'm sure it helps a bit, my oil still reeks of gas. Oh, and the drop in filters lean out the mixture by about .5 points, not 1 full point. A full intake with a larger maf housing will trick the ecu into running a lower load cell, which will run leaner air fuel ratios and more timing, and those will approach 1 full point. Either way, unless you are at extreme power levels, intakes and drop ins alike are both a waste of money once you're tuned.
Old Dec 26, 2008 | 11:29 AM
  #88
Q15H's Avatar
The attached oil **** report is from my new X MR at the first oil/filter change ~2500 miles. The fuel dilution is at 2.4% and silicone is at 90 ppm.
Old Dec 26, 2008 | 11:33 AM
  #89
blackchiney's Avatar
I just check my car awhile ago and the oil is very dark and smells like gasoline. I seem to have every issue possible with my car. I've had three reflashes, notchy transmission and now oil that smells like gas. Is lemon law a possibility here?
Old Dec 26, 2008 | 11:43 AM
  #90
dek0026's Avatar
so what are considered normal fuel in oil, viscosity and silicone levels?
