Blouch Dominator II vs FP Red - Pros/Cons
Old Mar 6, 2010 | 04:44 PM
  #61
Fidget253's Avatar
so the Dom 2.0 is much better for daily driving?
Old Mar 6, 2010 | 04:52 PM
  #62
mlomker's Avatar
This is an old thread. You should research the FP Green now as well.
Old Mar 6, 2010 | 05:00 PM
  #63
Fidget253's Avatar
alright thanks :-)
Old Mar 6, 2010 | 05:03 PM
  #64
cpunlamd's Avatar
T3 GT30/35R > Bolt on turbos
A T3 based turbo will make crazy power at lower psi (pump gas friendly psi). Why would anyone build their car around a small turbo? You would then need to run alot more boost and start requiring higher octane, race gas, meth, etc. Just to run a runt turbo..
Old Mar 7, 2010 | 07:14 AM
  #65
mlomker's Avatar
Better spool and $1200 for an FP versus $5k for an ETS kit would both seem like good reasons.
Old Mar 7, 2010 | 08:17 AM
  #66
.RYAN's Avatar
Not much was learned here.
Old Mar 7, 2010 | 09:53 PM
  #67
XRims's Avatar
We are running the Dom2 and I must say that surging is very irritable, and is most probably due to bigger blades yet same housing. That is the problem with bolt on turbo upgrades...
We'll be looking into solutions this summer.
Old Mar 8, 2010 | 08:52 AM
  #68
Fidget253's Avatar
i thought the DOM 2.0 doesnt surge?
Old Mar 8, 2010 | 10:28 AM
  #69
CBRD's Avatar
there is more to it than simply the size of the wheel, the aerodynamics also play a big roll!!
cheers
cb
Old Mar 8, 2010 | 06:40 PM
  #70
cpunlamd's Avatar
If you want stock spool, keep the stock turbo (its free). If you want big power, you gotta go with a big turbo.
Old May 5, 2010 | 05:13 AM
  #71
JED_POLAND's Avatar
CBRD and how would you compare your BB-X to Red and Dom 2.0 in terms of available power, spool, etc?
Old May 5, 2010 | 05:51 AM
  #72
mlomker's Avatar
His answer would be more power and he's achieved the same spool as a DOM on his dyno. Might just want to shoot him an email or PM if the info in the BBX threads doesn't answer your questions.
I'll be finding out very soon how the spool compares to a Red on E85. My car is finally running.
Old May 5, 2010 | 06:27 AM
  #73
murlo26's Avatar
Hopefully this week
And now the Red car on e85 is down...
Old May 5, 2010 | 06:32 AM
  #74
JED_POLAND's Avatar
More power than the Red?
You mean yours?
Old May 5, 2010 | 06:34 AM
  #75
murlo26's Avatar
You mean yours?
I don't think CBRD has really tested a Red, at least when i asked they hadn't.
And you are correct sir.
jaime8754
Jan 20, 2020 01:06 PM
finalx
12
Aug 2, 2016 08:07 AM
JamaicanEvo
Feb 16, 2010 05:40 PM
