need help!!! code P0140
Old Feb 23, 2009 | 09:00 AM
evox34's Avatar
sorry for my little english,Two days ago i connect the test pipe, ultimate racing and catback greddy, and now I get the P0140 code, which will be the code?
Old Feb 23, 2009 | 09:08 AM
CantStopSpinin's Avatar
P0140 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 2).... the pcm is not seeing the signal that the sensor is generating or something similar.
whats your question??
Old Feb 23, 2009 | 09:16 AM
evox34's Avatar
My question is whether the sensor is dead or what happens?,I have to replace the sensor?
Old Feb 23, 2009 | 09:17 AM
Draven83's Avatar
you are running a test pipe that is what is making you throw the code. If you want to get rid of it get a 02 simulator or put your cat back on
Old Feb 23, 2009 | 09:27 AM
evox34's Avatar
[QUOTE=Draven83;6728376]you are running a test pipe that is what is making you throw the code.
yes, but the ultimate racing test pipe,is ready to pledge that no code
Old Feb 23, 2009 | 09:34 AM
alex3dworld's Avatar
to be or not to be
that is the question
Old Feb 23, 2009 | 09:42 AM
evox34's Avatar
in spanish, monte el test pipe UR y despues de 2 dias me prendio el cel code P0140 ,se supone que con el test pipe no prenda, o no se si es que el sensor esta dañado ??
Old Feb 23, 2009 | 11:36 AM
macPSU's Avatar
So your test pipe is throwing a check engine light, and you want to know why, since the UR test pipe is supposed to come with a CEL fix, right? You should PM someone at Ultimate Racing to find out why you're getting the CEL.
Old Feb 23, 2009 | 12:41 PM
evox34's Avatar
yes , and the p0140 code ,is a sensor dead or by tespipe
Old Feb 23, 2009 | 01:04 PM
Spy007's Avatar
+1
If you are having issues with a product, contact the manufacturer (ultimate racing in this case) first. They usually will have some things for you to check, or keep you from doing un-necessary checks in case you dont have something.
tephra
Dec 17, 2024 01:36 PM
rico05
Mar 29, 2015 07:35 AM
EvilRob
Sep 8, 2011 04:50 PM
Yousef
Nov 6, 2009 05:30 PM
diddyX
Mar 13, 2009 09:15 PM
