EVO X 5 Speed failures and solutions
Old Jan 3, 2010 | 03:36 PM
  #121
Bear.914's Avatar
Originally Posted by mlomker
The day someone says "I've never launched or drifted my car but the diff pins broke" is the day I'll worry about it.
I would be curious about labor costs on this upgrade when my clutch has to be done. Has anyone bought the pins and had the work done locally? Just looking for a ballpark...
I broke mine, lets just say its so expensive the dealer hates me because there was issues with my warranty being voided after they re-approved me for warranty work lol
Old Jan 5, 2010 | 10:30 PM
  #122
escalade2346's Avatar
hey guys im looking to buy an evo x soon and im just wondering are these transmission problems happening on stock cars or cars that are modded?
Old Jan 13, 2010 | 12:21 PM
  #123
David Buschur's Avatar
A little update. My EVOX is apart right now, we are building the engine/head/trans/changing gears/building our GT35r kit etc. Tons of work going on.
My car has about 4,000 miles on it, the diff was worn out and the pins in it were in poor shape. We will have to use our oversized pin and have the diff honed, this is with only 4,000 miles on the car.
Old Jan 13, 2010 | 01:27 PM
  #124
Clipse3GT's Avatar
What is the production date on your car I am just wondering if this has something to do with models built in 2007 or in early 2008 as well. Any pictures of the damaged pins?
Old Jan 13, 2010 | 01:31 PM
  #125
Noize's Avatar
EvoM Administrator
Real interested to hear how you like the new final drive. Good luck with the build, its gonna be a beast.
  #126
hotdog's Avatar
In Mitsubishi's defense, Buschur's car has most likely seen a lot of hard launches
But yeah, will definitely be getting this done as well.
Old Jan 13, 2010 | 01:38 PM
  #127
Clipse3GT's Avatar
x2 Whenever my car will need a clutch these will get replaced as well. Probably at BR.
Old Jan 13, 2010 | 01:40 PM
  #128
murlo26's Avatar
Are the diff pins what's in question here?
Are they easy to replace when doing the clutch?
Old Jan 13, 2010 | 02:19 PM
  #129
Clipse3GT's Avatar
Might as do them when the clutch is out and tranny is out. It is just easier that way.
Old Jan 13, 2010 | 02:20 PM
  #130
Yes, the diff pins are what is in question, no they are not easy to replace, they are inside the trans.
Old Jan 13, 2010 | 02:25 PM
  #131
murlo26's Avatar
Well, I think I will be waiting then, i am going to be stretching the tax return as is with everything going in soon, lol.
Old Jan 13, 2010 | 11:39 PM
  #132
JC7119's Avatar
Any news on the final drive change?
Old Jan 14, 2010 | 12:37 AM
  #133
Brokenevo's Avatar
subscribed, looking to see more info on the improvements. If pins were failing, and we put in stronger pins, will this effect the parts the pins are attached to? Will this then cause other parts to fail?
Old Jan 25, 2010 | 11:50 AM
  #134
jwoodzx7r's Avatar
PM'd you
Old Jan 26, 2010 | 12:57 AM
  #135
The pin appears to be the problem at this time. You can only fix one part at a time and this is the first weak link.
