4B11 engine failure documentation thread
Old Jan 25, 2010 | 02:27 PM
  #46
jrsimon27's Avatar
at least it doesnt happen on stock evos or on mild modded evos just with bolt ons..
Old Jan 25, 2010 | 02:37 PM
  #47
DRAG's Avatar
Originally Posted by UT_EvoX
1.) 17000 miles @ failure
2.) Hole through side of block, at least 1 broken rod. Led to an oil fire which destroyed 1/3 of my engine bay. No symptoms up until catastrophic failure.
3.) Stock rod was either defective or they simply cannot handle 32+ psi on a CBRD BB-X turbo. From what I can see currently, the rod split clean in half and the big end is still in tact.
Moral of the story, the stock rods are weak as hell. I honestly spiked to about 36-38 psi 3 times on 3 partial pulls when I had some mapping issues with EcuFlash. That probably produced a torque spike of ~500 lb-ft which weakened one of the rods.
Oddly, the failure happened in 5th gear under 1/2 throttle while passing somebody going under the speed limit on I-29. I would convert back to stock and make the dealer fix it, but I honestly don't want another stock block that is incapable of handling a decent 450-500 WHP.
No tuning issues. 2-3 counts of knock max. 11.6 AFR with a large shot of methanol/water. Very conservative timing. 30-32 psi straight across from 3500 to 7500 rpm.
Must have just been too much for the stock bottom end to handle. *shrugs*
I'll find out soon if it was rod bolt failure, but it honestly doesn't look like that is the case. Nor should it have been because I neither make much torque nor rev past 7600 rpm.
edit: There are my modifications:
CBRD BB-X turbo, ported exhaust manifold & turbine housing, Invidia DP/TP/N1 catback, Cobb Intake + Inlet hose
Custom UICP, Snow Performance CH3OH/H2O injection, AMS inline fuel pump, 1000 cc/min DW injectors, Cossy fuel rail (doesn't matter, but just illustrating the adequacy of my fuel system), replaced OEM fuel relay w/ green one
You know when I snapped 2 rods in half you got an internet boner and tossed out a slew of "you are an idiot" comments and told me I didn't know what I was doing and that the stock rods are super strong forged pieces blah blah blah.
Exact thing happened to me. Perfect AFR, no knock, good pulls previous to breakage but with 50hp less. I guess you are swimming in your own **** now? That's too bad.
Old Jan 25, 2010 | 02:44 PM
  #48
DRAG's Avatar
Originally Posted by Noize
1) Mileage at failure
2) Symptoms of failure
3) Cause of failure
1. 12,000
2. No symptoms. Good AFR, no knock, car ran fine with 50hp less. Immediate carnage when it occured on a clean pull.
3. Stock rods broke clean in half, 2 of them in the same location. It was not a rod bolt failure in my opinion as one of the broken rods had a clean break and the rod bolts remained in tact. The bearings on that cylinder were "ok" as well.
Mods:
Turboback exhaust, Cobb AP, 200 shot of nitrous wet, 110 octane. Car ran 11s before the shot. I can only imagine that the 700+wtq @ 4000rpm caused the rod to break.
Old Jan 25, 2010 | 02:50 PM
  #49
RallyGoneEvo's Avatar
What I dont understand is why you guys think a STOCK internals can handle all this. Nitrous, 30+ lbs of boost on stock internals, is rediculous. I say if your gonna push the power, atleast beef up the most important part of the car.
Old Jan 25, 2010 | 02:52 PM
  #50
DRAG's Avatar
I couldn't agree more, but if guys like us weren't willing to push things a little then no one would ever know what they could or couldn't take right? I bought another stock motor and am building one for when I pop that one. I want another stab at going fast on the stock motor.
Old Jan 29, 2010 | 05:40 AM
  #51
KPerez's Avatar
I am a little confused here because DRAG in another post (https://www.evolutionm.net/forums/ev...-handle-7.html) provided his recommendations (he works in an engine building shop) regarding the limits of the OEM rods to be "100hp/cyl". Now assuming he meant wheel horsepower, I calculate that he was achieving ~473.5whp, i.e., >100whp/cyl, given his X's weight, trap speed and ET (3710, 116 and 11.4, respectivley) in his signature. So isn't a reasonable explanation for his and perhaps others failure be due to rod and or piston failure...or am I out of it here?
Later, Ken
Old Jan 29, 2010 | 07:42 AM
  #52
DRAG's Avatar
Later, Ken
I didn't mean that as the limitations, but just what I would allow if someone brought me that rod not knowing what it was from or anything about it. Obviously, people are making more than that.
My times in my signature are misleading. I ran 11.7 @ 116 on the stock turbo (93mph in the 1/8). My 11.4 pass was spraying a good size shot of nitrous and I went 103 in the 1/8th then hit the rev limiter in 4th which scared me pretty good on the spray...so I coasted to the 11.4. 7.2 @ 103 should work out to a 10 second pass around 130 or so...but that would be bench racing
Old Feb 28, 2010 | 01:06 PM
  #53
dkstas's Avatar
1. 6300 miles
2. Big cloud of smoke, loss of oil pressure and power, a quart of oil spewing out of my tail pipe
3. Drag racing, ring land failure on #4 psiton...No logged knocks unitl after the incident. Still rolled to 12.0 @ 86mph
Old Mar 1, 2010 | 06:58 PM
  #54
futurevowner's Avatar
What mods did you have when you blew?
Why can detonation not cause a rod failure if the rod is weakened over time?
This is not to say that your particular case was one significant knock event but knock can cause a rod failure.
Old Mar 10, 2010 | 07:38 PM
  #55
mikebutler's Avatar
Pretty much stock at 10k miles, spontaneous piston disintegration
Old Mar 11, 2010 | 11:03 AM
  #56
DRAG's Avatar
Damn. What kind of power and what type of driving are you guys doing that are hurting pistons?
Old Mar 11, 2010 | 11:51 AM
  #57
MarkM's Avatar
may as well add my pics here too
Old Mar 12, 2010 | 10:01 PM
  #58
ajs's Avatar
ajs
First time - 5,000 miles, in 5th gear, 1/2 throttle, at 50 mph...car shuddered and white cloud of smoke. melted piston 4 right at the piston ring gap.
Old Mar 12, 2010 | 10:14 PM
  #59
Brokenevo's Avatar
mods?
Old Mar 13, 2010 | 03:32 PM
  #60
mrfred's Avatar
And the other three pistons are ok, or do they have a lesser amount of damage? If its just piston #4, seems kinda strange that it would be the only one to toast.
