Analyzing a critical engine flaw in the 4b11 by TTP
Old Apr 30, 2010 | 05:27 AM
  #241
tephra's Avatar
well you bought it up
regarding the rings..
heat makes any metal expand, the rings when the heat up expand... since the rings are held in place by the cylinders they have only one direction in which to expand... That is why there is a gap to begin with...
Old Apr 30, 2010 | 05:41 AM
  #242
tsitalon1's Avatar
Playing devils advocate, because it's fun....
What about gapless rings? how is that possible then?
Old Apr 30, 2010 | 05:44 AM
  #243
tephra's Avatar
dont know about them
maybe they are made from metal that only expands in one direction...
Old Apr 30, 2010 | 06:45 AM
  #244
JED_POLAND's Avatar
Originally Posted by LESTERH
And I'm pretty sure the FQ400 has 400 flywheel HP. So pretty much an X w/ bolt-ons and a tune.
But look - piston expands, gases are pushing them out and what, they STILL manage to meet at the ends?
I am not saying it is not possible - I am just trying to understand HOW and WHY.
Old Apr 30, 2010 | 06:47 AM
  #245
tephra's Avatar
im guessing the pistons and cylinder walls (sleeves?) and rings are all made out of different materials...
which by definition means they have different expansion rates..
Old Apr 30, 2010 | 06:57 AM
  #246
JED_POLAND's Avatar
I fully agree. But HOW the piston rings ends can meet:
- liners expand
- pistons expand
- rings expand in length but get pushed outwards
Can all this be overcome by the length expansion?
Do we have someone here who is good at physics and/or metallurgy + knows something about the engines and could explain that?
I keep asking since I first read what TTP posted few months ago and I still don't get it.
Same with the question: does it happen in untouched engine?
Old Apr 30, 2010 | 07:14 AM
  #247
tsitalon1's Avatar
Don't know if it helps, but can't hurt:
http://www.stockcarracing.com/techar...ics/index.html
This supports TTP's stance:
http://www.aa1car.com/library/ring_end_gap.htm
Straight from JE pistons:
http://www.sytyperformance.com/je_rings.pdf
Old Apr 30, 2010 | 07:26 AM
  #248
mrfred's Avatar
- liners expand
- pistons expand
Cylinder liners - Made of steel, CTE is smaller than aluminum. Higher temperatures will increase cylinder diameter. Combustion forces will try to expand the diameter of the cylinder.
Pistons - Made of aluminum, CTE is higher than steel. Higher temperatures will increase piston diameter and open up ring gap. Combustion forces will increase piston diameter and compress the piston (perhaps even having an effect on the ring gap).
Rings - Made of steel, CTE is higher than aluminum. Higher temperatures will increase the diameter, circumference, and thickness of the ring. Combustion forces will push down on the ring and tend to expand the diameter and also increase the circumference.
If someone tells me cylinder pressures and temperatures, I can generate some real numbers on the change in dimensions of each of these components.
Old Apr 30, 2010 | 07:29 AM
  #249
Golden's Avatar
Gapless Rings either have notches that overlap or are made of 2 rings. Either way they allow overlapping of the ends so that there is room for them to grow.
I think I know what you guys are missing. Yes the Piston can and will Expand, but there is room for it to grow, as the ring slot is deeper than the ring's width. So as the piston grows, the ring just gets closer to the piston.
The Sleeves Don't grow that much, because they are cooled by 180* water in the jacket outside. So the rings have nowhere to go. The End Gaps get narrower.
Old Apr 30, 2010 | 07:54 AM
  #250
kwanza's Avatar
Originally Posted by TTP Engineering
Number 1 = 0.007 min
Someone mentioned forged pistons with different expansion rates. Are the Mahle stock pistons forged?
Yes, the stock Mahle pistons are forged. Tomei did an article in Turbo magazine when the X first came out comparing the differences 4b11T to the 4g63T.
Old Apr 30, 2010 | 07:59 AM
  #251
JED_POLAND's Avatar
Thanks for trying to explain.
The "sleeves" grow that much I would say - pressure test the cylinder on cold and on hot engine - you will see.
Old Apr 30, 2010 | 08:03 AM
  #252
JED_POLAND's Avatar
Well, I have a feeling that it was the only place to say so.
Old Apr 30, 2010 | 08:11 AM
  #253
tephra's Avatar
so whats your point? you don't think the ring ends can touch?
Old Apr 30, 2010 | 08:17 AM
  #254
mrfred's Avatar
That explains the effect of temperature, but do the cylinder pressures really high enough in these motors to squish the rings and force them to expand further?
Old Apr 30, 2010 | 08:29 AM
  #255
JED_POLAND's Avatar
My point is that it sounds almost impossible that the factory miscalculated the tolerances so badly.
However with the engines producing 150% and more of the original power it is a different story as they require some bigger tolerances.
Moreover, if the stock pistons are forged, aren't they supposed to withstand much more thus be harder to damage?
But STILL - how big the miscalculation had to be to make ring ends touch?
