Forgot small oil filter on motor reassembly
Old Nov 20, 2010 | 05:10 PM
scheides's Avatar
EvoM Moderator
I got flustered looking for a lost tool and forgot to put in this small oil filter/restrictor (?). Is this worth puling the head back off (and a new HG) for? Service manual lists this as the Engine Oil Control Valve (OCV) filter.
TIA.
Old Nov 22, 2010 | 01:04 PM
plan:b's Avatar
I would think that w/o it, oil pressure might be affected.
Old Nov 22, 2010 | 01:48 PM
07outty's Avatar
could you put it back in by removing the control solenoid
from the outside of the engine and pushing it in someway ?
..or does it not go where i am thinking it does ?
Old Nov 22, 2010 | 08:21 PM
scheides's Avatar
EvoM Moderator
It goes perfectly verically, with the little 'fin' side up, somewhere well into the block. No easy way to put it in but yank the head back off. Facepalm.
Old Nov 22, 2010 | 08:35 PM
05VIII's Avatar
Sucks..but engine failure because you were to lazy to do it right would suck more.
I dont know if it's needed or not, but if it was there before I wouldn't risk it. Sucks you have to take it all apart again but better safe then sorry
Old Nov 23, 2010 | 08:42 AM
plan:b's Avatar
It happens man...(cliche phrase that wont make you feel any better, coming up next)...
Well look at the bright side, at least you found out now!
Old Nov 24, 2010 | 11:46 PM
evo542's Avatar
that looks like the filter for the MIVEC system, I say put it in unless because if the actuators get jammed with debris from the engine, it will throw a code and the car wont have the correct valve timing
Old Jul 3, 2022 | 05:39 PM
John Ryan's Avatar
Head gasket
I forgot to put mine in. For some reason I thought it was in the head and noticed after I had everything torqued down. I have ARP 625s so I don't see a problem with head Studs, but do you think I'll be okay reusing my 5 layer head gasket?
Old Aug 6, 2022 | 06:15 AM
shiroseb's Avatar
Question about this thread
Sorry to revive such an old thread, but would anyone here happen to know what would occur to oil pressure if the car is run without the OCV filter mesh? Im assuming it would lower oil pressure. Would appreciate feedback.
TIA.
Old Aug 6, 2022 | 07:27 AM
John Ryan's Avatar
Torpedo Filter
So I believe it won't be an issue for your engine if you were doing MIVEC delete... but it could screw up MIVEC since that filter restricts pressure to the Mivec system. You can retorque the same head gasket down since you haven't applied heat. I forgot mine and had to take it all apart to put the filter in.
mdknutsen
Jul 3, 2017 10:42 PM
RallyGoneEvo
42
Jul 20, 2011 04:42 PM
kungfugirl
For Sale - Part Outs
15
Jul 25, 2008 04:20 PM
ralliart610
May 30, 2008 11:55 AM
pearlwhiteoz
19
Sep 27, 2002 08:58 AM
