FP Red, Green or Black?
Old Jan 22, 2011 | 07:49 AM
  #46
blues2k03's Avatar
I was in the same boat as you, but I made the decision to go ahead and go with the FP Black. From everyone that I spoke with, the spool difference between the FP Red and the FP Black is minimal. In addition, after looking at what my future plans are, I just didn't think the FP Green was going to cut it.
Old Jan 22, 2011 | 12:40 PM
  #47
utggevox's Avatar
Originally Posted by tsitalon1
This is absolutely not true. Each gear produces a different load at any given rpm point. Hence why we spool faster in 4th than in 2nd.
The Lag of a larger turbo is usually more prominent in the lower gears where there isn't as much load to spool it. Remember turbo's are load driven.
I'll try to get a 1st and second gear pull in the next few days.
keep in mind though that murlo is running e85 and with e85 your going to spool faster no matter the turbo. Hence why murlo's black spool is just as fast as some greens, reds and bbx's that are running pump. My buddy has a red w/ full bolt ons running e85 and im on pump 91 stock turbo with full bolt ons minus fmic and his red spools only 200-300 rpms slower.
EDIT: Here is link for the Virtual Dyno graph. http://www.utahpace.com/forums/attac...1&d=1272253023
Keep in mind that when this VD graph was done the only mods i had was intake and test pipe.
Old Jan 22, 2011 | 12:44 PM
  #48
philamthebest's Avatar
the black needs a fuel pump upgrade and the spool time is quite different from what i understand.
Old Jan 22, 2011 | 01:19 PM
  #49
utggevox's Avatar
I agree although most guys running reds and greens have upgraded fuel pumps also. The spool with the black on pump is indeed slower than the green and red on pump but when your comparing the black running e85 you are going to see faster spool which explains why murlos spool is just as fast as some smaller turbos. Of course though if you decide to run the black on e85 (or even 26+psi on pump) on stock block you are driving around a ticking bomb. That explains why the red and green may be a more logic choice for those who dont want to spend the extra money and time to build up an engine.
On a side note though how is the red treating you?
Old Jan 22, 2011 | 02:38 PM
  #50
lowkey's Avatar
Registered User
no as fp keeps telling me the order wait is longer and longer, i think there is a 12 week wait.
Cobb here in Texas is not far away from FP and they collaborate. They might have one in stock for you. Or try another shop, maybe someone has one laying on a shelf.
Old Jan 23, 2011 | 01:06 AM
  #51
blues2k03's Avatar
I have called every major vendor; AMS, MAP, Vivid Racing, AWDMOTORSPORT, and several different Cobb facilities, and no one has an FP Red on their shelves.
Old Jan 23, 2011 | 05:10 AM
  #52
zeus1's Avatar
Here is my green on the Virtual dyno:
Here is my Green turbo "feelings":
https://www.evolutionm.net/forums/ev...n-journey.html
Enjoy!
nice is that 93 pump?
Old Jan 23, 2011 | 11:26 AM
  #53
lowkey's Avatar
Registered User
Here are 3 different cars, but on the same dyno. All 3 on E85. The FP-Green (blue lines) and the FP-Red (red lines) have very similar mods and both have Kelford B cams. The 3rd car is a Cobb Stage 2 with a stock turbo. You can clearly see the peak torque and power are progressively later from stock turbo to FP-green to FP-red turbo. I guess it all depends on street vs track use for the car, but the FP-Red looks laggy for normal day to day driving.
Old Jan 24, 2011 | 02:21 AM
  #54
fknchristoph's Avatar
what would make more power (hp and torque)
Dom 2.0
FP red
with these mods:
ams fuelpump kit
dw 800's
agp intercooler pipes
agp 3.5 i/c
injen intake
3 port boost solenoid
atp downpipe
tial ewg
artisan raceback exhaust
a toon.
sorry to thread jack
Old Nov 6, 2012 | 12:19 AM
  #55
clichere1's Avatar
Hi guys ... saw all the discussion and opinions, I think Red should do for me but I want your help regarding something else.
I'll be running 97oc (on the pump) soon, and wonder if the generated heat from the upgraded turbo should affect my options (green or red).
The car is for DD use, track it once a month for fun not racing, my target is 420whp max. And planning not to go for higher whp's, as this would force me to modify the engine to avoid any failure. I would like to keep the car for 5 years failure free as much as I could
I'm thinking to install the turbo and get a tune from Cobb SoCal.
Any advice?
my current mods below.
Thanx
Old Nov 10, 2012 | 05:33 AM
  #56
Showbizz41's Avatar
Any advice?
Thanx
Stick with the Red then... But, at that power level you dont need to build the motor.. Necassarily. Watch the torque and at what rpm the torque is peaking
Old Nov 11, 2012 | 04:06 PM
  #57
940Marine's Avatar
I'm trying to decide between the FP Red and the GTX3071r, i read about the GTX3071r sounds good but i dont know anyone haveing one. I have a 2010 EVO X
Old Nov 11, 2012 | 04:09 PM
  #58
940Marine's Avatar
Oh yeah my horse power goal is between 450 to 480 on 93oct.
Old Nov 12, 2012 | 02:55 PM
  #59
940Marine's Avatar
GTX3071r, FPred, BBX Full and Map EF3 wich one can get me closer to 450 to 460hp with the right supporting on 93oct.
superkizuna
Dec 14, 2013 05:57 PM
evolutionaryevo
Nov 19, 2013 08:57 AM
khmerguyx
Oct 4, 2013 07:07 AM
Sieu Toc
13
Jun 25, 2013 07:31 AM
