Aftermarket Exhaust Manifold Heat Shield????
Who is interested in seeing a turbo exhaust manifold heat shield that is design for aftermarket exhaust manifold? I have not seen anything like this being sold. The heat shield would be bolted to the exhaust manifold bolts. The enclosed area would be oversized to fit the larger exhaust manifold. The heat shield would have to be a two piece design so you can have access to the exhaust manifold bolts. The heat shield would incorporate a small top vent with a flap over top, just like the stock heat shield.
This is something I am looking for. Unfortunately I don’t have the tools or the metal fabrication techniques to manufacture something like this. I would like to see a vendor design something like this.
Here's my new setup:
MAP short-runner exhaust manifold with a custom heatshield to protect the plastic valve cover! I also got MAP's firewall and sensor shields, but those are production pieces with pictures on their website so I didn't bother taking any. The manifold is coated internally with MAP's black ceramic (same that's on my turbo).
https://www.evolutionm.net/forums/9990004-post45.html
I emailed map performance about that turbo manifold heat shield and they said they would only make it if they had 10 buyers.
I like the turbo manifold heat shield that map performance made, although i think they should have made it cover over top of the manifold and part of the turbo like the stock heat shield.
I am sure one of these manufactures would make one but i think we need to show some interest in the product. I could make some getto fab heat shield, but it not something i want. I prefer a clean OEM look.
Many other people are just suggesting running exhaust wrap. I hate the exhaust wrap. It looks ugly. It soaks up water and causes corrosion on your manifold. I prefer some thing more aesthetically pleasing.
I also dont believe that ceramic coating the exhaust manifold is enough to reduce the heat radiation.
Its important to run a heat shield on the evo X since the turbo is so close to many other components. AMS shows that one of their cars started on fire because of the lack of heat shield
https://www.evolutionm.net/forums/ev...atch-fire.html
yeah, deffinitly interested in a heat shield.
in the design you showed, does that basically eliminate the need for the gasket to the head?
https://www.evolutionm.net/forums/sa...old-cover.html
I think this may be what your looking for. I bought one, and it works great, plus gives a cool look. Everyone asks, "wow, whats that"? lol
Bom's Evo
16
Apr 15, 2013 06:10 AM
Red Dragon
Automotosports - Illinois
Feb 20, 2012 07:46 AM
