Cobb BOV lost its blowing sound
Old Mar 4, 2013 | 04:53 PM
Gyroscope's Avatar
Originally Posted by Joe's Evo X
Remember 6000 Feet the air is really thin. So no air to push thru the BOV until pressure is built up lol. Sea level tons of air (IE more HP) so normally u will be able to hear it easy at sea level. FYI if your tuned for sea level be careful taking it to an extrem elevation change like that. Most times you do need a tune for a change like that if you plan on pushing the car hard.
lol at needing a retune to take a vacation. these ecus suck
Old Mar 6, 2013 | 06:54 AM
Kracka's Avatar
Hardly. I've drive both my Evos all over this country, and continent, and never once had an issue. Given a proper tune, others shouldn't have an issue either. You do need to make sure you're running the proper fuel for your tune, which is why I have both 93 and 91-octane tunes on my ECU, and an E85 one ready to go if I ever decide to go that route.
Old Mar 7, 2013 | 12:53 PM
evo10fanatic33's Avatar
Veteran: Air Force
Is a tune required for just a BOV on a stock GSR? I want to get a HKS SSQ4 but I'm not sure if that BOV goes well with the X's and if I need to tune. I'm just over paranoid about screwing up the motor or the ECU? Thanks.
Old Mar 7, 2013 | 02:13 PM
Sunwalker12's Avatar
Never thought a tune woukd be required for a simple BPV/BOV
Old Mar 7, 2013 | 02:27 PM
evotap's Avatar
if its recirc'd its fine. you shouldnt be venting to atmosphere in any maf car
Old Mar 7, 2013 | 02:28 PM
True that but the X does work off of MAF and speed density...however ill never reccommend venting to the atmosphere lol
Old Mar 7, 2013 | 02:31 PM
desiromeo812's Avatar
A Retune might be required if your stock BOV is leaking. In that case the aftermarket one will hold more boost which can be a problem if you are not tuned for it
Old Mar 7, 2013 | 02:39 PM
Very good point...thanks for the input man...
Old Mar 7, 2013 | 05:26 PM
Veteran: Air Force
So basically I have to get the recirculate kit with the BOV? If I recirculate will I still get that great HKS BOV sound?
soon2bEVOIX
19
Oct 7, 2017 12:03 PM
jakebehan95
Aug 7, 2015 02:53 PM
Zlord8
10
Jul 24, 2009 02:00 PM
Chuckdimpala
11
Jul 19, 2009 05:09 PM
BlueEvolution
Jan 14, 2008 11:26 PM
