Changing valve springs with out removing head
Old Jan 1, 2013 | 09:35 PM
evokid4life's Avatar
So here soon i plan on doing a set of cams in my X im going with AMS TMP cams which require valve springs
So me being lazy i was gonna attempt to change the valve springs with out taking the head off.
Is it a good idea?
Anyone here ever done it this way?
Any recommendation if i do it this way?
Thanks in Advance guys!
Old Jan 2, 2013 | 05:13 AM
scheides's Avatar
EvoM Moderator
I was going to try this on my car but ended up not doing it and yanking the head. Once you get the new cams in plan on ALL of the cam clearances to off and ordering lots of new buckets, thn fiddling around with them for weeks trying to get the clearances right. This is what I did durin my engine build and it was a huge PITA.
Just yank the head, bring it, the springs, the cams, and your buckets (still assembled and in order!) to a machine shop and have them deal with it. I had a valve job done and fresh valves put in last week (see build thread) and try literally had it done in hours, not days!
Then
Re-assemble with a good quality set of headstuds and a fresh OEM gasket and you're set.
Old Jan 2, 2013 | 09:40 AM
racerx43269's Avatar
ok.... they make a TOOL for this... and you actually need a bunch of tools... a compression checking tool ( used to fill the cylinder with air so you dont drop a valve.. and the spring compressor tool.. mine was done this way... yours can be also... I didnt have to change my buckets and/or shims.. and i put in 274's
Old Jan 5, 2013 | 07:26 AM
Thanks for the input guys!
Old Jan 5, 2013 | 09:44 AM
Snakes709's Avatar
I would take the head off. But if you want to do it the lazy way. Do what i did (i had my head off and engine apart but you can still do it this way) All you need is like a 22mm socket, socket extentiion, rubber mallet and one of those magnatic pole things. Place the socket with the extension on the valve spring retainer. Give it a good hit the the rubber mallet. The spring will compress and the retaining clips will come off. They will most likely fall into the head which is why you need that magnetic pole.
As for getting the springs on, iiunno because i havent gotten that far..lol
By the way I, in no way, am responsible if you try this ****ed up method and screw your car up.
Old Jan 5, 2013 | 11:26 AM
lol thanks for the input man
nope i dont blame other ppl for what i do lol
but im actually having a friend whos done it before this way help me do them.
Old Jan 6, 2013 | 09:18 PM
goevox's Avatar
you can try using the valve spring compressor tool.
Old Jan 7, 2013 | 07:17 PM
havent done it yet but thats what i plan on using
Black_EVO_MR
Nov 9, 2016 05:10 PM
evoniners
May 16, 2016 06:04 AM
jeri534
26
Mar 2, 2014 02:10 AM
tsidrift1
23
Nov 9, 2013 06:10 AM
GGevo921
Jan 29, 2012 06:38 AM
