ACD/AYC pump failure reports
Old Aug 26, 2013 | 01:22 PM
SamsonEvoX's Avatar
year: 2011
first sold: 7/24/11
pump started to fail: 23,000 miles-near 100 degree temps
pump failed: 23,000 miles [pump is being replaced]
cold-start reflashed: never
Update: Mitsubishi will not cover the pump because it has a tune on it! I am so ticked.
Old Aug 27, 2013 | 10:53 AM
AFD's Avatar
AFD
YEAR: 2010
1ST SOLD: DEC 2009
PUMP STARTED TO FAIL: ~28,100 MILES (AUG 2013)
PUMP FAILED: ~28,300 MILES (AUG 2013) (don't think it's 100% dead yet, but dealership says it needs replaced - diagnosed 2 weeks after "4WD SYSTEM SERVICE REQUIRED" dash warnings)
COLD START REFLASH: YES, TSB-SC11-002 APPLIED AFTER PUMP WAS ALREADY FAILING. (requested all applicable TSB & ECU updates in DEC 2012 and other visits prior during 3-year warranty, invoices stated everything was up-to-date).
* Dealership will not cover ACD pump under Mitsubishi 5-year/36,000-mile powertrain warranty (out of 3-year warranty by 8 months, though still under mileage). Currently in arbitration with corporate. More info here, if needed (LINK).
* 100% covered & already repaired (not covered by warranty, but Mitsu Corp goodwill according to dealership / covered due to low mileage according to Mitsu Corp)
Last edited by AFD; Sep 10, 2013 at 09:22 AM. Reason: CLARIFICATION 8/27; UPDATE 9/09
Old Aug 29, 2013 | 12:22 AM
9gt's Avatar
9gt
Its an evo X RS (in UK)
year: 2008
first sold: 10/2008
pump started to fail: 26,000 miles 08/13
pump failed: intermittent but got worse over the course of a week
Old Sep 9, 2013 | 11:44 AM
chundizzy's Avatar
year: 2011
first sold: NA
pump started to fail: Failed at the time of purchase of car
pump failed: Car has 50k miles on it but it was failed when I purchased it so I am guesing in the 40k-45k range
Cold-start reflashed -- No
Old Sep 11, 2013 | 06:40 PM
FetorHepaticus's Avatar
year: 2008
first sold: 11/2008
pump started to fail: approx 22,500 miles, 12/2011 on a week of below freezing temps
pump failed: after i brought it to the dealer and reflashed, they said it needs to be replaced
cold-start reflashed: reflashed when i brought my car to the dealer after the warning light came up, didn't resolve the problem.
*i knew my warranty was up, but i didn't mention it at first. my dealer was willing to replace the pump under warranty, then he called me again and said that my warranty just expired.
* i asked my dealer to price match the pump that's being sold by mitsubishiparts.net ( $350 cheaper ), they did.
Old Sep 11, 2013 | 07:23 PM
nrt5pitt's Avatar
year: 2010
first sold: 12/2010
pump started to fail: 44,370 miles (09/2013)
pump failed: 44,370 miles (09/2013)
cold-start reflashed: Never
Mitsubishi powertrain warranty would not cover dealer said they had seen it before and thought it was butt cheeks; however, car is 100% stock and I have a solid 100,000 mile 3rd party warranty which covered replacement in full. Will rebuild the pump after I determine cause of failure and dissasemble jic I need it later.
Old Oct 1, 2013 | 07:48 AM
soupxn's Avatar
year: 2008
first sold: 2/14/2009
pump started to fail: 48,000 miles (8/2013)
pump failed: replaced before failure
note: was also told that it was not covered by the 5/60 warranty. $2k to replace at dealer.
Old Oct 29, 2013 | 09:27 AM
Gooseman396's Avatar
year: 2010
first sold: 8/2010
pump started to fail: 16,500 miles (8/2013)
pump failed: 19,000 miles (10/2013)
cold-start reflashed: 8/2013
Old Oct 30, 2013 | 07:20 PM
adrianTNT's Avatar
Angry
Year: 2008
First Sold: ~ 2008
Pump failed: Dec 2012 / 30,000 miles
Cold start re-flash: none (dealer says they have no flash/update for me)
Motor brushes burnt and blocked, probably because of the ticker oil during winter. It was winter's lowest temperature.
Old Nov 12, 2013 | 05:17 PM
EvoStig's Avatar
Year: 2008
First Sold: 9/2011
Pump Started/Failed: 44,000 miles (6/2013)
Cold start re-flash (6/2013)
Was not covered by extended warranty.
Old Nov 19, 2013 | 03:47 PM
ice1874193's Avatar
year: 2008
first sold: 12/1/2008
pump started to fail: no warning
pump failed: ~54,000 (11/3/2013)
cold-start re-flashed: had my car flashed a few times - not sure if they did that one
30 or 40 F when I heard a screeching noise and got the light/codes. located in upstate NY
Old Dec 6, 2013 | 07:15 PM
mrccptx19's Avatar
Year: 2010 Evo X GSR
Failure Started 110,000 miles
Failed 119,000 miles
Un-Failed (Light/Message went off) 124,000
Failed again (Light/Message Back on) 128,800
Old Dec 24, 2013 | 06:47 AM
nhsean69's Avatar
Year: 2008
first sold: 10/2008
pump started to fail: 50,700 miles (12/17/2013)
pump failed: 50,800 miles (12/18/2013)
cold-start reflashed: 12/19/2013 (Dealer confirmed did not help and pump needed to be replaced. $1,995.00 quote)
Old Jan 9, 2014 | 08:07 PM
Pep's Avatar
Pep
Year: 2010
First sold: May 2010
Pump started failing: Dec 2013 - 40000kms
Confirmed that it is not covered by warranty.
Pulled the relay out before pump motor seizes while I am ordering the rebuild kit from acd tuning.
Edit: For those wondering which one is the ACD pump relay:
Old Jan 17, 2014 | 10:26 PM
nexgen's Avatar
09 ralliart
started at 23,000 miles
bought it used with 18,000
dealer won't warranty it!
