Stage 3 clutch slipping
Old Sep 9, 2013 | 08:47 PM
FINCHY78's Avatar
I have a cc stage 3 clutch with a cc lightweight fly wheel. The problem I'm having is slipping in first and reverse, especially on an incline. It is so bad I am afraid of driving my car on a trip, worried I will get stuck trying to climb a hill from a stop. I'm thinking, is this due to the lightened fly wheel? Do I need to install the stock steel one? I'm sure I'm not the first person to have this combination. Any help please!
Old Sep 9, 2013 | 10:48 PM
Scarlett X's Avatar
A lightened flywheel simply reduces the amount of rotating mass the engine must spin thus freeing up some horsepower and allowing the engine to rev faster.
When it's slipping is it fully engaged?
How many miles are on the flywheel / clutch?
When you do a pull does it slip?
Here's a good read for you-
http://www.evoxforums.com/forums/showthread.php?t=55971
Old Sep 10, 2013 | 08:53 AM
cfdfireman1's Avatar
I've only seen slipping in higher gears because of the higher loads. This is a baffling problem.
Old Sep 10, 2013 | 11:02 AM
FINCHY78's Avatar
Does not slip under higher loads, only from a stop. Seems either it will stall out if I don't give it enough gas, but when i do it slips. Then I have to keep re-engaging the clutch with it slipping to finally move forward. This clutch has less than 3,000 miles on it.
Old Sep 10, 2013 | 01:32 PM
Now I'm really confused, why do you have to "keep re-engaging the clutch" if it's slipping?
Old Sep 10, 2013 | 02:17 PM
Iowa999's Avatar
This is sounding more and more like you just need practice driving a heavy car with a light flywheel.
Old Sep 13, 2013 | 05:52 PM
FINCHY78's Avatar
I had a stage 2 with lightened fly wheel and did not have this problem. Re-engaging is maybe not the proper term, because the problem is its not engaging, I have to push the clutch in numerous times until the car is moving then its fine. I have noticed some times when I let the clutch out I feel the car to begin to move forward with out pressing the gas, it is engaging and there is no slipping, this happens about 30% of the time. The other times I can slowly let the clutch out all the way to the top with it not engaging, and that's when I have a difficult time getting into first gear from a stop. Could air in the system be doing this?
Again, thank you for any input.
Old Sep 13, 2013 | 06:47 PM
That sounds like the slave is not working properly or the friction disk is sticking on the input shaft of the trans. Who did the install?
Old Sep 14, 2013 | 06:42 AM
After thinking about this awhile it sounds like you may have a clutch adjustment problem.
Try this.
Old Sep 14, 2013 | 01:41 PM
GsrJake's Avatar
I have the same set up, no problems here
Old Sep 15, 2013 | 03:33 PM
FINCHY78's Avatar
A local shop did the install, I recently replaced the CMC due to failing.
Old Sep 15, 2013 | 03:44 PM
FINCHY78's Avatar
Try this. http://www.youtube.com/watch?v=vYJxQyjIhUw
Thank you, that's a great video! I know my mechanic did not do this, I asked about the adjustment and he made it sound like there wasn't much adjusting to do, and it wouldn't make a difference. Definitely calling this guy back up.
Old Sep 30, 2013 | 06:43 AM
Updates?
Hao Tan
Mitsubishi TC-SST Discussion
May 17, 2016 12:16 PM
Hao Tan
May 15, 2016 08:40 AM
sammyrex
Apr 11, 2015 05:40 AM
McSlides
Oct 17, 2014 09:44 PM
awdfun
Jun 7, 2014 11:04 AM
