FIC 2150 too much for 93? (6266)
The only place for me to get E85 is a performance shop about 20 mins away. After that my closest one is about 2 hrs. Im looking for an injector that will work with 93 and E85 and can push enough fuel for a 6266.
2150's are good for 1500 whp on 93 octane. Do i think its overkill? No, because once you buy them you never have to replace them. Dont be like me and buy and sell 3 different sets of injectors. Either way you cant install any injector without properly scaled by a tuner. Might as well buy once and they will meet any future goals. Just my 02.
A good tuner certainly helps but even the best tuner can't change the fact that our IPW only goes so low and only stays so stable.
On the evo 8/9 you have access to more tables for idle etc. On the X, i would not do 2150's on 93.
I have arguably one of the best tuners for the X and on e85 I still wasn't super happy with the driveability of the fic2150's. I think I had a set that wasn't balanced too well though and personally would recommend the ID2000's over the FIC2150's.
Wait for the 1600's as I said on the other forum...you won't regret it.
good thinking!
I think you've gotten some good feedback here about the 2150s on pump gas. They can be more work to dial in but the feedback we hear is usually very positive. It does depend on your tuner and the ability of your ECU to control those short pulse widths, but with the newer technology high impedance injectors we use they do a very nice job all around.
We also offer Data Match Technology now which helps the injectors run even better in that tough short pulse width area by ensuring the injectors are matched by both slope flow rate as well as individual latency value which is really nice. We give all of this specific matching info to you as well so you can see the results and also use them to input in to your ECU for the most precise calibration possible. You can read more about that and see a video on it here:
http://fuelinjectorclinic.com/data-match-technology
Hi murlo, I just wanted to ask that you please give us a call so we can make sure everything is right with your injectors and setup as a whole. I am confident that our products will perform as well or better than anyone else's on the market today and our customer service is top notch as well... give us a call at (561) 427-0082 and we'll make sure you're taken care of.
tscompusa
Aug 19, 2014 06:31 PM
Phantom X Evo
Evo X Dyno Results
Oct 24, 2012 05:01 PM
