1st gear transmission whine
Old Oct 31, 2016 | 02:46 PM
02modlanceroz's Avatar
I took my car to the track and did 2 passes in it. Now I'm getting 1st gear whine. It only does it if the car is in 1st gear, the car is moving and the clutch pedal is pushed in (disengaged). There was a kid on the Evo X forum that had the same issue. But never posted an answer to the problem and he hasn't wrote me back either
Old Oct 31, 2016 | 03:47 PM
infam0usndn2nv's Avatar
i got the same exact issue....it happened when i after a pass on the track. i just got use to the noise now but if u do find the solution please share.
Old Oct 31, 2016 | 05:30 PM
Will do my man. Hopefully you'll do the same. Did you check fluid level or drain it yet?
Old Oct 31, 2016 | 09:49 PM
4b11slayer's Avatar
Normal in my eyes.
Old Nov 1, 2016 | 09:18 AM
hoobastnk90's Avatar
Yea I would say pretty normal stuff
Old Nov 2, 2016 | 07:30 PM
hydro334's Avatar
Originally Posted by 4b11slayer
Normal in my eyes.
Yeah mine has done this since day one. It's pretty subtle though.
Old Nov 2, 2016 | 08:18 PM
Does yours do it with the clutch pushed in or released? Mine only does it when I disengage the clutch. Doesn't do it with it engaged or with a load on it.
Old Nov 2, 2016 | 10:22 PM
Ig88's Avatar
Yeah, my MR does that when in SuperSport...totally normal for me, but i'm probably the minority SST here
Old Nov 3, 2016 | 07:49 AM
LetsGetThisDone's Avatar
Its an Evo thing. First gear makes noises. The gear has a very shallow helical angle for strength, which makes it noisy. My car on a 2-1 downshift sounds like a kenne bell supercharger on an 04 cobra...lol
Old Nov 4, 2016 | 06:06 AM
Hahaha, that's exactly what it sounds like. I just got worried because it started doing it after my 1st time at the track. Will it get any louder or sound worse with more launches?
My old fox body t5 mustang sounded like that. But it was because the main bearing on the countershaft was worn. Ended up locking the tranny up on me lol.
Old Nov 9, 2016 | 05:16 PM
They get louder with some wear.
Old Nov 15, 2016 | 08:34 PM
Evo302011's Avatar
Sounds like its normal thing.
dtuned
Jun 4, 2009 02:02 PM
rr06rs
10
Oct 18, 2007 11:48 AM
adamhw
23
May 6, 2006 12:50 PM
93esp
13
Aug 10, 2005 12:32 PM
zstryder
Jul 12, 2005 12:19 AM
