Precision 5858 Turbo Issues
Old May 11, 2018 | 04:46 PM
  #76
RazorLab's Avatar
Originally Posted by ETS Michael
The only other thing I have that might be different is a HUGE drain.
I have a drain like this
Its 7/8" ID right off the turbo and goes down all the way to the block where it necks down to 5/8 (-10AN)
- Robert
Yea I think the drain is the issue. The interesting thing I found out is that if I fill the engine with oil to the top line on the dipstick it smokes more than if it's towards the lower part.
The MAP kit has a smaller drain fitting. I would replace it but it's next to impossible with the turbo already on the car.
Old May 12, 2018 | 05:29 AM
  #77
pkware's Avatar
Got mine to stop after the welded 10an fitting as well but I'm still running the restrictor.
Old May 15, 2018 | 12:24 PM
  #78
laxhero2's Avatar
I am having the same issues with smoking to. I am also running the BB 5858. Tuner called Precision turbo and Precision asked them to install a oil pressure regulator and make sure the drain are 10an all the way through. Also, asked us to try a recirculating setup for the catch cans. The shop I am working through is nice enough to refund me the VTA setup and get me a Dual Radium setup. I'll let you know how it goes next week how it goes.
Old May 15, 2018 | 02:35 PM
  #79
LetsGetThisDone's Avatar
Need to follow What Robert did. Just recirculate isn't enough, you need larger hoses and fittings on the valve cover as well.
Old May 15, 2018 | 02:53 PM
  #80
laxhero2's Avatar
I’m already running -10 AN fittings and lines for the catch cans. The setup I am running is similar to the Driven Fab catch can. I will more than likely run the same setup Michael has. But my intake doesn’t have a hole in it to run the line. So I’ll have to drill one out.
The other solution that was suggested is running a larger size fittings for the drain. I am pretty sure I am already running a -10 AN. But I think the fittings are tapper from 20mm-13mm.
Like razorlab says, it’s a pain to replace the fittings and lines with the turbo on. But I might do it soon though because the smoke is just annoyning me. I Just don’t have the time.
Migsubishi
Nov 18, 2016 03:13 PM
Dr.G
Sep 9, 2015 10:45 PM
Boostin Perform
13
Oct 28, 2014 07:24 AM
ETS Michael
ExtremeTurboSystems.com – WA
10
Apr 27, 2012 03:42 PM
4ag18psi
Apr 10, 2012 05:57 PM
