Rear Diff and Transfer Case filling procedure
Old Apr 1, 2018 | 02:50 PM
ticaaal70's Avatar
Just to double check (2014 Evo X GSR)
The best and safest method to fill the transfer case & rear diff (not the YAW side) according to jacks transmission:
-drain old fluid
-fill them both with a quart of LSD gear oil through the drain plug
-drop the car off the jackstands and drive around for abit
-put the car on jackstands and open the fill plug to allow the excess to come out.
Transmission + YAW control is drain and fill.
Correct right?
Old Apr 3, 2018 | 08:39 PM
Blue_Lion's Avatar
https://www.evolutionm.net/forums/ev...l#post11812289
Found this thread. Hope it’s helpful to you. There’s a picture that should serve as confirmation. Also, from reading that I’ve done as well, when lifting the car, make sure it’s evenly leveled. If not and at an angle, it can make it so that theres not the recommended amount of fluids. Should be a no brained but doesn’t hurt to mention.
Old Apr 4, 2018 | 11:48 AM
LetsGetThisDone's Avatar
-drain old fluid
Correct right?
Yes, that's correct and the easiest.
josh_evo9
26
Dec 29, 2016 03:28 AM
Dvolution
Aug 5, 2013 02:06 AM
Evo02l
Jun 8, 2012 01:11 AM
rcheung
19
Nov 29, 2007 09:11 AM
honda-guy
Jul 25, 2007 06:24 AM
