Sponsored by:
Sponsored by: CARiD
AGP Turbo's EVO X
Old Jan 25, 2008 | 01:39 PM
  #61
Asta4125's Avatar
Originally Posted by FastCoEVO
I love all the haters. The Evo X will me making power. All of you IX owners need to just accept the fact that the Exo X is better.
HAHA Yea I know its funny isnt it. Its like they view the car as a foreign country with global control of oil. Soo funny to hear the stupid asumptions people are making like the dude a couple posts ago that said, oh the X's ecu is already good, since it already has advanced timing, so there wont be much to gain out of it. WHAT?!!??!?!?! Yea your right, the aspect of advanced timing is all that gets tuned when your tune an ecu. Not a/f, gain, injector duty cycle...nothing, just timing, which acording to that guy, will not be able to advance anymore since its sooo far advanced. Got asumption is the mother of a f ups.
Old Jan 25, 2008 | 01:40 PM
  #62
dave12285's Avatar
wow this is pretty exciting. 320/320 with no tuning is quite nice considering i made 331/318 with everything in my sig plus a full tune from TT.1
Old Jan 25, 2008 | 01:42 PM
  #63
BOOSTEZ's Avatar
Originally Posted by Guerillah
Youre assuming the X ECU is much more tuned than the IX ECU. Quit making assumptions. There is a lot to be gained just through the air fuel ratio alone and if indeed the car is knocking on 91 there is good power to be gained there as well. These are two things that we know now as fact, and can be fixed and show gains. Did the evo ix knock on pump gas with simple mods?
Assumptions are being made that the X will gain the same with a flash as a IX. That's just silly, especially since most cars that are IDENTICAL don't make the same power.
AGP mentions that the timing was pretty aggressive. The boost already peaks at 23psi. The IX's turbo boost stock was barely peaking 19psi in most cases - plenty of room for power. If you think you've reached your boost max, how much more power do you think you can extract from the car with just timing and AFR without causing knock and not adding race/meth? Probably not as much as you'd think/hope.
Old Jan 25, 2008 | 01:45 PM
  #64
BOOSTEZ's Avatar
Right.. like the IX was over the VIII. And the XI will be over the X..yea, we get it...
Better is subjective.. Take the car to the track and see what it can do with full bolt-ons and the added weight that it comes with.
  #65
evilution310's Avatar
different dynos dude.
Old Jan 25, 2008 | 01:48 PM
  #66
BOOSTEZ's Avatar
Please tell me how these are tweakable to add more power?
  #67
Eviloution310,
Are you stupid?
Look at the dyno I posted of the ix... It drops down to 13psi. Use your eyes and brain before you start trying to talk ****. As far as the dynos being different no ****. Did I ever mention numbers? All I stated is when peak occurs on each sheet. I'm not comparing numbers so get a damn brain before you trying saying I have no idea what im talking about. Comparing peaks between these two dynos is fine as they both put the car under the same type of load.
No I think your pretty stupid trying to compare different dynos on different days you just look like an a.s.shole. Did you take things into consideration like load(which is different between a dynapack and mustang like your comparing) On a dynapack you take the wheels off and dyno at the hub where as a mustang you dyno wheels on, what about ambient temp? which could make all the difference in the world. Do you see what im getting at? you cant compare 2 things that are wildly different and expect not to get called out about it.
Old Jan 25, 2008 | 02:03 PM
  #68
Ramocheese's Avatar
We should have some lap times to compare to UMS's EVO 8 after this weekend. As was mentioned earlier, the car will be at the NASA Time Attack event tomorrow.
Old Jan 25, 2008 | 02:04 PM
  #69
Guerillah's Avatar
Both dynos are LOAD BASED, do they make the same exact load, no, but the mustang puts more load on the car (hello heavy *** wheels it has to spin?!) which favors spool up for the IX.
Temp affects POWER YES, I never compared power directly between the two. All I compared was when each peaked, at what boost, never did I say ohh well the X makes this much hp vs the IX making this much power. If I made power comparisons then yes I would agree with you but I never did. I was pointing out curves. The only reason I even posted that IX dyno sheet is because someone was on here saying the IX doesnt taper the boost like the X does which it clearly does.
Old Jan 25, 2008 | 02:20 PM
  #70
BOOSTEZ's Avatar
Laps are good. But quarter-mile times is what people are really interested in. Sorry but on the street (where most racing occurs), people won't be trying to race around corners unless they are foolish.
Old Jan 25, 2008 | 02:21 PM
  #71
Ramocheese's Avatar
The car will most likely go to the drag strip immediately after the time attack event, or the following day.
We hope to have some comparison times of all flavors by the end of the weekend
Old Jan 25, 2008 | 02:28 PM
  #72
Guerillah's Avatar
I thought the nasa time attack event was next weekend?
EDIT: NVM, I was looking at the 2007 schedule like an idiot.
Old Jan 25, 2008 | 02:35 PM
  #73
UMSTuning's Avatar
its tomorrow @ PIR
Old Jan 25, 2008 | 03:59 PM
  #74
Jorge T's Avatar
different methods to generate load, dynapack=hydraulic power absorbers, mustang= eddy current power absorbers.
Old Jan 25, 2008 | 04:40 PM
  #75
Ramocheese's Avatar
Not the greatest pics, but here are a few of the car stickered up for NASA tomorrow:
