Sponsored by:
Sponsored by: CARiD
problem getting into reverse
Old Mar 28, 2008 | 05:43 PM
no0odlez623's Avatar
so i woke up today to go to school and it was a colder then avarage morning in flordia... around 61 degrees...anyway when i try to put my car in reverse.... it wont get in gear...i thought i was doing something wrong...but 5 gear was a little hard to get into as well... so i had to fumble with my gear box for like 30 seconds before i could get the car into gear... but after i drove it a while everything was fine... is anyone else having this problem? should warming up the car fix this?
Old Mar 28, 2008 | 05:53 PM
EvoXstylin's Avatar
i've never had that problem, and my car hasn't even seen 60 degrees. hopefully it's a one time thing.
Old Mar 28, 2008 | 06:01 PM
Keepster13's Avatar
I already know you never had a DSM! At least a stick one.... The gearbox is far from perfect in some Evo's. I laugh at your "cold" at 61 degrees! I would kill for 61! Thats so hot! Don't worry to much about it till puts out a recall. Till than welcome to the habit that has plagued all us DSM owners... Shift into first than shift into reverse. Works like a charm.
Just my thoughts
Old Mar 28, 2008 | 07:07 PM
Just my thoughts
okay 1st then reverse... sweet! thanks dude!
Old Mar 28, 2008 | 07:16 PM
angryjon88's Avatar
the shifter bushings on evo's suck... my car and my friend's 9 are the same... just play around and shift while you're warming up in the morning so they're easier to put into gear
Old Mar 28, 2008 | 07:42 PM
EJxxx's Avatar
I 2nd these comments.
Old Mar 29, 2008 | 01:11 PM
Tunerhead's Avatar
Never had this problem either but good to know the 1st gear trick.
Old Mar 29, 2008 | 03:22 PM
blanknotice's Avatar
Mine does that every once in a while too. Put it in first, let the clutch out a bit to engage, then put it in reverse and you should be ok. It only seems to happen to me when the first gear I put it in is reverse after sitting a long time.
Old Mar 29, 2008 | 07:28 PM
lefty's Avatar
Shifting to reverse when cold is often difficult in a lot of cars. I wouldn't worry about it unless it persists even after the car has warmed up.
Old Mar 29, 2008 | 08:00 PM
TheBlueBlur's Avatar
Buy these, and all of your problems will go away.
http://lancershop.com/customer/produ...9&cat=0&page=1
Old Mar 29, 2008 | 11:41 PM
Jonasan50's Avatar
Doesn't matter if it's an EVO, eclipse, or whatever.. All manual trannies do that every once in a while. The synchros get out of alignment and going to 1st or 3rd before reverse aligns them back. No problem..
Old Mar 30, 2008 | 12:09 AM
JapanEvo4's Avatar
^^^Agreed! I even had a Exedy Hyper Racing Clutch in my Evo IV and sometimes (especially in Japan's winter) it was a real PITA to put it into reverse. Nothing to really worry about.
Old Mar 30, 2008 | 09:19 AM
boybeatertsi's Avatar
Just my thoughts
That's exactly what popped into my mind!! Yea First then reverse .. but also you can try lifting up on the clutch ever so slightly until u feel it pop in .. becareful not to stall it .. lol ..
Old Mar 30, 2008 | 10:53 AM
Rootus's Avatar
I've never had it happen on a car with a synchronized reverse. You'd have to push the clutch in and hold it for a few seconds and let the synchros stop spinning, just don't make that a habit and you'll always be able to shift into reverse just fine.
This assumes the Evo does in fact have a synchronized reverse, of course. I don't know of any modern cars that don't, off the top of my head, so it seems likely.
Old Jun 13, 2008 | 05:01 PM
m98evolution's Avatar
On the Evo 8, you have to put it in 5th gear first when it's hard to get it in 1st or Reverse.
Victor Hong
Jul 13, 2016 08:19 AM
mrmiller
Jun 21, 2016 07:08 PM
alby988
17
Apr 8, 2009 05:48 PM
navidf
Jul 25, 2008 11:26 PM
oogieboogie
15
Jul 7, 2005 05:36 PM
