Sponsored by:
Sponsored by: CARiD
E brake question?
Old Mar 26, 2009 | 09:26 AM
Xtremist's Avatar
E brake question?
I've been having a re-occurring issue with my X, after parking the car in my garage and setting the e brake and letting it sit over night the car makes a loud popping noise and doesn't want to take off right away, like the e-brake it still applied? Is there a good possibility the e brake needs adjusted? Is anyone else having this problem?
P.S. I always make sure the e brake is fully released and the clutch has plenty of life left, the car moves but feels as though the e brake is still applying it's self??? I've never tracked the vehicle or modded the car what so ever! BTW it's only when the car sits over night... Thanks
Old Mar 26, 2009 | 10:32 AM
mitsubaru's Avatar
I had the same issue on my WRX. But during the summers it would be fine....I guess it has something to do with the cold weather....jut a thought
Old Mar 26, 2009 | 10:49 AM
steinvb12's Avatar
Maybe try not to put the e-brake on quite as hard. If it's only in your garage you can probably get away with 2 clicks. You don't need to pull it all the way.
It grabs pretty nicely.
Old Mar 26, 2009 | 12:23 PM
devinclfalcons's Avatar
Did you wash your car the day before by chance?
Old Mar 26, 2009 | 12:36 PM
pmoney559's Avatar
Old Mar 26, 2009 | 12:48 PM
Under PSI's Avatar
The brakes could simply be sticking or freezing to the rotor temporarily depending on how cold it is outside and how warm the brakes get.
Old Mar 26, 2009 | 01:04 PM
If your brakes got wet there could be temporary rust on them. This happened to me a few days ago after I washed it. It took some hard gas to get it to "pop".
Old Mar 26, 2009 | 02:44 PM
Xtremist's Avatar
Yeah I live in Ohio and I do wash my car and it rains/snows a lot so this could be a determining factor! I notice my brakes usually stink after I get out of the car, so it could be the whole "hot then cold" situation fusing the brakes to the rotors... I bought some hawk brake pads so maybe I should swap the pads out and see if this relieves the issue, not that it's really an issue just gotta be careful or the car will stall since I give it little to no gas taking off. Thanks guys!
Old Mar 27, 2009 | 12:17 AM
zTargeTz's Avatar
mine do this and i thought it was freezing water.. haha
Old Mar 27, 2009 | 05:34 AM
Xtremist's Avatar
Yeah it's a very odd feeling, first time I had ever experienced this out of all my manuals...
Old Mar 27, 2009 | 03:30 PM
ryanowarrior's Avatar
yea mine done this as well i was like wtf the first time i washed it
Old Mar 27, 2009 | 05:14 PM
Mark B's Avatar
It's the pads freezing to the rotor .
Old Mar 27, 2009 | 05:38 PM
mdesi's Avatar
+1
This happens to me quite a bit. My WRX, VIII and now the X all do it. Its usually during the colder months.
StancedEvoX23
47
Sep 7, 2013 06:49 PM
19DB794
Aug 3, 2013 07:25 PM
MICLOIV
12
Jan 25, 2010 01:23 PM
SyZyGy1394
13
Oct 6, 2009 09:57 AM
eag36
Apr 17, 2007 05:29 AM
