Sponsored by:
Sponsored by: CARiD
Brake warning light...
Old Oct 13, 2009 | 10:41 AM
poof101's Avatar
Ok, ive noticed that everytime i go into a corner,especially when making a left turn at a decent speed my warining light comes on. It the one with the exclamation point and parentheses (!)...i looked it up in my manual and it says check brake fluid. Ive checked the brake fluid and everything is good..ive made an appt with the dealer but wanted to know if anyone else has had this problem.
Old Oct 13, 2009 | 10:48 AM
Dr. Ev0L's Avatar
your brake fluid is most likely on minimum. eventually the light will be on all the time as your brake pads wear further. i would get the pads checked to see where they are at. that light is a warning but sometimes the fluid is a little low from the factory.
Old Oct 13, 2009 | 11:00 AM
rcheung's Avatar
Your brake fluid could be sloshing causing it to trigger the light when turning. It still means that the fluid is at or near the low mark and either you have a leak in the system or pads are getting low.
Old Oct 14, 2009 | 02:38 AM
trickyazn's Avatar
I would bet more than likely the pads are low rather than a leak in the system. You can always check the brake resevoir.
Old Oct 14, 2009 | 07:22 AM
stikllr13's Avatar
Same thing happened to me, it IS an indicator that your brake fluid is low. Top it off! Problem solved.
Old Oct 14, 2009 | 11:58 AM
rcheung's Avatar
The problem is not solved only bandaid. If the low fluid indicator light is on something is wrong.
Old Oct 14, 2009 | 03:54 PM
tokeone's Avatar
your fluid goes down as your pads wear. you get the indicator when youre pads are past halfway done...
trust me
add some fluid, and know that new pads are not far behind
with 50k miles on my car, ive been through this a few times
Old Oct 14, 2009 | 10:40 PM
poof101's Avatar
thanks for the advice..i have 11,000 miles on my car..just had it serviced last month so i guess its the pads...my fluid looks good.
Old Oct 14, 2009 | 10:44 PM
m0nkie's Avatar
I hit 20k.. had that problem n it was my pads wearing out..
Old Oct 14, 2009 | 10:46 PM
poof101's Avatar
i heard my brakes squeak a lil the other day too so i guess its time for new pads...how much does the dealer charge for new pads on average?
Old Oct 15, 2009 | 11:44 AM
tokeone's Avatar
well the thing is if the fluid is slightly below full this happens because on braking or hard acceleration the fluids movement exposes the censor enough...
even if it looks full add more fluid.
your pads should probably be good for a few more thousand miles. id say they probably have about 40% life left. thats pretty much how its been everytime its happened to me.
which as of yesterday is my third time.
Old Oct 15, 2009 | 12:20 PM
Deception's Avatar
Don't go through a dealership for new pads, they over charge like crazy... if you're looking for less performance pads along with less brake dust and squeaking, you should check out some silicon pads...
Old Oct 15, 2009 | 12:37 PM
m0nkie's Avatar
I just ordered some Ferodo DS2500 pads for 280$... my shop said they can order oem pads for about 280 too... so I decided to upgrade a lil..
Old Aug 23, 2011 | 07:21 AM
bluepeartype-s's Avatar
Registered User
I know this is an old thread but, I'm glad I found this...I've been running arcoss the same issue. Now my brake light is staying on and I've got no e-brake or brakes pushed. If I push the brakes the BRAKE light goes away. I guess I'm going to have to buy brakes...only @ 32,000 miles
-B
Old Aug 23, 2011 | 07:24 AM
T6's Avatar
T6
for zie community Fluid might be just fine but not the pads. I recently noticed it's been taking me a bit more distance to stop so I had my pads checked and they were at 4mm instead of 10mm. I didnt replace them yet but I will replace them in 2 weeks as I will gain at least 100 whp/wtq this saturday lol. Not sure if I will go with the "factory" pads though.
AKB_EVO
Jan 20, 2016 03:00 PM
03nevaevolution
Jun 6, 2013 03:21 AM
limx
Feb 28, 2012 07:36 PM
goofygrin
10
Feb 28, 2009 06:27 PM
EclipseMblue
Nov 10, 2008 10:35 AM
