Sponsored by:
Sponsored by: CARiD
Most Regrettable Evo Parts Purchases...
Old Dec 20, 2009 | 01:59 AM
  #106
theFLASH12's Avatar
Originally Posted by mlomker
Okada plasma coils & HKS plugs. Don't do anything that a tune on stock parts wouldn't do.
If you want to sell the coils and plugs please PM me...
Old Dec 20, 2009 | 06:15 AM
  #107
raytrix's Avatar
Originally Posted by Hassan!
1.HKS Hi-Power Exhaust <--- Light and good performance for track, Very LOUD for DD.
2. AEM Air Intake <------------ Bad quality but awesome performance.
How is the AEM intake bad quality, is it the form and fit or is it just you don't like how the turbo inlet tube is not metal?
  #108
DarwinX's Avatar
Could you be more specific about your AEM intake complaint?
I have an AEM intake and I love it. Fit & finish is great, install was a breeze, and I've had no idle issues at all since installing it.
Old Dec 20, 2009 | 06:20 AM
  #109
Evo VIII 4G63's Avatar
i like my aem intake as well.
Old Dec 20, 2009 | 06:51 AM
  #110
mlomker's Avatar
Originally Posted by migs647
a pure CDT Audio set up to the factory mitsubishi fosgate set up.
I hear that...my BMW had the CDT HD-52's but the stock head. I'd love to do a system with Eclipse source and CDT drivers but it's not worth it on this car...it's noisy by design.
Wasn't planning to get rid of them, it's just a bit expensive for bling is all.
Old Dec 20, 2009 | 09:05 AM
  #111
chriswolf81's Avatar
Originally Posted by Weapon X
if you have the peak/hold ones, check your wiring. the power wire (red?) needs to be hooked up to a constant 12v source to remember your settings (ie alarm value and beep disable) and the other one to the 12v acc switched (orange or white i think?) to turn them on. if you have them both hooked up to the 12v acc, theyll work, but the beep disable and peak/hold features wont work (no pwer when the car is off, wont remember settings). press and hold the button and start the car. it should be disabled for good. the only con i found with these is that because of the need for constant 12v, it will drain your battery faster if you let it sit for 10-14 days (in my previous car that is).
hope this helps...
Very interesting. You are probably 100% right and I never thought about this.
I am still getting the ZR-2 gauge, since it plugs right into my ZT-2 and I can monitor AFR digitally in the middle, while monitoring Boost on outside ring. Or maybe the opposite. I just don't like any pod options, so one gauge looks cleaner.
Old Dec 20, 2009 | 09:07 AM
  #112
monkey_187's Avatar
Eibach Pro springs
Old Dec 20, 2009 | 09:48 AM
  #113
aftershock141's Avatar
Originally Posted by hotdog
The SSS package with Navigation.
Removed the wing, sold it for pennies, and have a Kenwood DNX9140 sitting under the Christmas tree, from myself.
Well damn, that was a logical use of money
Sell me your nav for cheap.
Old Dec 20, 2009 | 09:52 AM
  #114
Remove.
Old Dec 20, 2009 | 11:14 AM
  #115
theFLASH12's Avatar
Did you have any noticeable gains in power from this Okada coils & HKS plug combo set?
Old Dec 20, 2009 | 11:15 AM
  #116
migs647's Avatar
Oh he has an VIII... this is just for the Xs guys. See the Evo X General section? Xs only. There is already a very lengthy Mod Regrets thread in the 8-9 threads.
Old Dec 20, 2009 | 01:30 PM
  #117
mlomker's Avatar
I don't add my mods one at a time (not sure who could afford dyno time like that). In any case, my car doesn't make 1hp more than the many cars that my tuner has done without the Okadas. X's are already COP so there's not a lot of room for improvement.
I actually had misfire issues and have swapped the plugs back to stock for now.
Old Dec 20, 2009 | 07:57 PM
  #118
Farmerbob's Avatar
What was the "bad quality" on the AEM intake? Did it not bolt up properly, or did you need to fabricate parts to make it work? It seems like a lot of Evo X's are running the AEM intake b/c it's CARB approved.
How did the performance improve with the AEM intake?
Old Dec 20, 2009 | 08:07 PM
  #119
Hiboost's Avatar
Originally Posted by lillev23
Oh yeah. My aquamist hfs-1. Definitely not the safest way to make over 400hp. Also my buschur racing 65mm TB. The whistling noise gets aggravating at partial throttle. Maybe I should've gone with Mil-spec
I'm thinking about an Aquamist, best bet to make it safe is to have the error code trigger a low boost mode in some manner so that it's not as dangerous if it ever fails.
Slight regrets:
AMS "Race" front motor mount - It does help smooth out shifting when the engine would otherwise be flopping around mid corner or throwing the car around, but I think the street version would likely be stiff enough for 90% of the people out there.
Old Dec 20, 2009 | 08:09 PM
  #120
TTP Engineering's Avatar
Slight regrets:
Installing it correctly goes a long way too. If you do not think you can do it correctly, leave it to a professional to get it installed right.
