(maybe) dumb question bout MR's
Nope, the SST is an Automatic, or Simi-Automatic, or Automated clutch manual if you will. The SST rev matches auotmagically on both down-shifts and upshifts; cool stuff!
as for your smg and having to press the gas to rev match up shifts... that's really weird. in a full manual car, when you up shift, you don't gas it... you just time your clutch so that when the rpms drop in enough, you engage. gassing it will actually slow down your up shift since you have to wait for the needle to drop again. why does your car need throttle to up shift?
Top that off wth coming into a 90 degree corner and trying to accelerate out as quickly as possible in normal mode, the tranny has a serious amount of lag. Manually shifting down to prepare for the corner, is much better.
I use the paddle shifters about 10% of the time when driving in manual mode. Not often, but I use em. I prefer to use the stick to shift.
Your best bet is to google: dual clutch systems or sequental manual gear boxes. Those setups are the same for the EVO MR. The EVO MR's tranny is acutally built from the same plant that BMW's SMG is built from. The dual clutch system is perfect for single turbo applications, as well as track cars. If you want to drop the clutch at 6k RPMs and slide around the corner, GSR is your bet.
...as for your smg and having to press the gas to rev match up shifts... that's really weird. in a full manual car, when you up shift, you don't gas it... you just time your clutch so that when the rpms drop in enough, you engage. gassing it will actually slow down your up shift since you have to wait for the needle to drop again. why does your car need throttle to up shift?
I sometimes scare myself when I think of all the electronically controlled stuff in my Evo X MR-T that could (and probably will ) break!
SHIFTT IX MR
Apr 7, 2009 03:08 PM
