Sponsored by:
Sponsored by: CARiD
Stage 2 29 psi+, help!!!
Old Jun 29, 2011 | 11:03 PM
harpreet1012's Avatar
I received my invida down-pipe with cat delete (+ already stage 1 withe Q-300) today and installed it and uploaded the cob stage 2 91 oct LWG map and i was pushing 29 psi , then i changed back to stage 1 91oct LWG and still same problem.
I had to take my intake off the car to get to the bolt on the down pipe, and it ended up being a whole turbo housing removal, maybe a loose vacum hose?
Also in not throwing any code from my 02's sensors. Also boost pill is still not removed.
Old Jun 29, 2011 | 11:49 PM
JDMCT9MR's Avatar
Are you hearing any unusual noises?
Old Jun 29, 2011 | 11:56 PM
guswaym's Avatar
remove the boost pill. do a datalog with the lwg map and without post them up here
Old Jun 30, 2011 | 02:00 PM
no unusual noise i can hear ill have to listen to it again and ill get a post up for a mapping once i get home
Old Jun 30, 2011 | 02:05 PM
ugakirk's Avatar
I thought you have to remove the boost pill to run the stage 2?
Old Jun 30, 2011 | 02:31 PM
ikt's Avatar
ikt
you do, so it's odd that its hitting 29 psi. Is that a gauge reading?
Old Jun 30, 2011 | 04:41 PM
jellyevo's Avatar
maybe WGA??
Old Jun 30, 2011 | 07:50 PM
i went through the whole car again and found that a vacum hose had a crack in it (probably from me) and i replaced it and falshed the car on stage 2 91 oct lwg and it fixed it(24 psi +/- .9, well thanks for the help anywats
Mohannad
Cobb AccessPORT
Jul 11, 2020 05:40 PM
ckevoxnyc
Cobb AccessPORT
10
Jun 1, 2016 03:30 PM
dw0095
Cobb AccessPORT
Jul 12, 2013 11:08 AM
GetterDragun
Oct 7, 2010 08:07 AM
bluegsr
Aug 7, 2010 11:18 PM
