Sponsored by:
Sponsored by: CARiD
Clutch Hose Leak - FYI
Old May 29, 2012 | 11:44 AM
esquire7's Avatar
Just throwing a issue out there that from searching doesn't seem like a common issue but figured I would give info on my particular issue for anyone who ends up getting the same problem.
I noticed last friday that when depressing my clutch in for longer than the normal shift (holding in at stoplight in first, traffic stop n go) my clutch would engage first gear fine but would not come back up after about a quarter way...I would need to grab it with my toe and pull it up. I have a 2011 with only 9K on it so it was dreadful to feel that knowing the common clutch issues with EVOs.
I noticed that when shifting normal at speed the clutch worked fine so I assumed this was some type of pressure loss/leak only when depressing the clutch. What I figured out when I opened my hood was that the main clutch hose coming out from the master cylinder which runs over to the clutch was squirting like a squirt-gun (pinhole) up towards my hood, leaving brake fluid all around my brake fluid resevior and red battery connector every time I depressed the clutch.
Makes sense that when holding in the clutch it would keep spraying which emptied out the fluid in the lines causing a drop in pressure and the clutch didnt have enough power to come back up. I put a temporary piece of hose tape on it so it wouldn't spray up towards the engine block but rather just drip down from the wrapped tape.
The only fix is for a new clutch hose assembly (A). Figured someone else may come across this issue and could use this to quickly know they need a replacement hose. I didn't find much searching for this specific issue. A little surprised this hose busted only at 9K...must be cheap part.
The car is drivable but will leak the fluid if I get stuck in traffic and losing all brake fluid cannot be fun.
Taking to dealer for new hose and a bleed.
Old May 29, 2012 | 12:52 PM
AWDTerror's Avatar
A lot of people have not been impressed with the way the stock clutch system is set up.
Old Jun 5, 2012 | 10:29 AM
esquire7's Avatar
Update: Took to dealer for service...they said it was a fluke as his suspicion was that some type of projectile punctured the actual hose and was not a mechanical failure in the sense of faulty equipment. Replaced hose and bleed lines. Fixed.
close
Old Jun 5, 2012 | 10:37 AM
TheBlade's Avatar
glad to hear Mitsu fixed it up for you, hopefully with no cost to you...even though it may have been a road-hazard that caused it
Old Jun 5, 2012 | 02:38 PM
jeffo24's Avatar
This happened to me too at like 5k. Got a new MC under warranty. Hope they covered yours!
Kainvorador
Feb 4, 2018 09:12 AM
bbong
Jun 11, 2017 05:25 AM
WpgDave204
Apr 21, 2017 06:08 AM
crypto
Lancer How Tos / Installations
22
Feb 1, 2017 11:39 AM
corndog17
Lancer Tranny/Drivetrain Tech
Feb 26, 2011 03:53 PM
