Sponsored by:
Sponsored by: CARiD
Evo X - Model Year Differences
Old Jun 21, 2012 | 08:55 PM
ugakirk's Avatar
Originally Posted by SkylineFanatic
There also appears to be a power difference in the 2012 over the previous year’s affecting tuning - see existing thread:
https://www.evolutionm.net/forums/ev...-variance.html
I put that on the first thing under the 2012s.
Anyway, there is a reason that some tuners are making around 15-20whp less some 2012s. I believe that the answer will come out before the year is up. Some people are saying they have different cams, but I think it is going to be something tuning wise that needs to be done.
Old Jun 22, 2012 | 01:22 AM
digitalskillz's Avatar
You can indeed open a 2012 with just the door handle. you just push the black button with your thumb, while pulling the door handle with your 4 fingers.
As long as the FAST key is in your pocket, the door unlocks/opens.
Old Jun 22, 2012 | 01:44 AM
E\/0 X's Avatar
I have a 2009 GSR (middle east spec, so yes it is a 2009 ) It came with the full rockford fosgate system with the sub, fast key entry system, 6 disk CD changer, rally art tail lights, but has the tacky orange/red LCD in the cluster, no sat nav and no areo kit.
Just thought I would share, seems I have an unusual mix of options.
Old Jun 22, 2012 | 05:06 AM
ugakirk's Avatar
Yea 2009s are basically the 2008's with the ralliart tails. The RF system, fastkey, and everything come under the SSS package. In 2009 the Lancer Ralliart was released and used the black tails, I guess they just put them on Evos too.
Old Jun 22, 2012 | 05:41 AM
Hardware's Avatar
2012 Touring Package added an auto dimming mirror compared to previous years. That's all I know.
Old Jun 22, 2012 | 06:18 AM
HudsonFalcon's Avatar
I believe they dumped the DRL's with the later years Evo's as well.
Old Jun 22, 2012 | 07:01 AM
ugakirk's Avatar
No. That's not correct. 2012's still have DRLs.
Old Jun 22, 2012 | 08:51 AM
surefooted's Avatar
No. The 2008s have a sensor that unlocks the car as soon as you slide your hand in the door. No button needs to be pushed. Not the same thing.
Old Jun 22, 2012 | 09:47 AM
ALEXD3498's Avatar
So from all the years of evo x, the 2011 is the best one to get if you were looking for a used evo gsr?
Old Jun 22, 2012 | 11:18 AM
surefooted's Avatar
Always buy the newest car you can afford. If there is a used 2012, but it.
Old Jun 22, 2012 | 11:52 AM
Oops you're right my bad.
Old Jul 25, 2012 | 01:57 PM
BillCosbysPudding's Avatar
My base model USDM 2012 GSR does NOT have DRL's.
Old Jul 25, 2012 | 02:17 PM
Thegame's Avatar
Somewhere along the line Mitsubishi changed the design of the manual transmission shifter cable bushings as well. This became very confusing trying to purchase aftermarket metal ones. There isn't a great deal of info on it either. But I do know that several bushing manufacturers have different part numbers for different model years. Anyone know the differences?
Old Jul 27, 2012 | 02:52 PM
mr_jackson's Avatar
That's news to me. I would like the know the differences too.
Old Jul 27, 2012 | 03:36 PM
Panda_stunter's Avatar
Usdm 08 evo x underhood and in-dash bushings different than edm and usdm 10, though the usdm '10 and edm has the same bushings.
2008 and 2010 fast keys doesn't need to push the button on the door handle, u just slide ur hand as if to open the car and it will unlock as long as the fob is within range.
I believe I've read somewhere that 2012 x has different clutch master cylinder than previous years.
And like its been said before, tune is different on each model year being 2011 the leanest out of the factory since its making baseline slightly higher than 08 and 10. I'm not sure about the 12 though. 08 baselines at 230-240hp, 2010 @ 240-250 and 2011 @ 250-260.
