Sponsored by:
Sponsored by: CARiD
Vibration on highway
Old Feb 3, 2013 | 02:00 AM
Scrapin 240's Avatar
Hi,
Just picked up a new X GSR that had 4 miles and test drove it. And all seemed well. On the way home after buying it, on the highway as the speed increases there was a vibration in the steering wheel, to the point it can numb my hand.
So, is this normal?
Old Feb 3, 2013 | 05:18 AM
FastAttack's Avatar
Originally Posted by Scrapin 240
Hi,
So, is this normal?
no.
Take it back to the dealer and have them align it and check the tires for balance.
Old Feb 3, 2013 | 05:49 AM
Kouki Monster's Avatar
^ this
Old Feb 3, 2013 | 05:57 AM
dek0026's Avatar
how long did you drive it on the highway? if it's been sitting for days in this cold weather you may just have to get some heat into the tires. it usually takes me about 7-10 miles for it to smooth out. if that doesn't do anything then you probably need the wheels balanced.
Old Feb 3, 2013 | 10:28 AM
I believe the car was delivered Jan 29 to the dealer, I picked it up yesterday, 2/2, and put about 16 miles on the highway.
The dealer said check the tire pressures...which I was going to do, but it started to snow, and I hoped that the dealer itself would have given me the car with the correct pressures, but I guess that would be asking too much from a stealership.
Old Feb 3, 2013 | 10:45 AM
menasor's Avatar
My tires (Ventus V12) have been flat spotting more in the winter due to the cold. I usually get vibrations in the morning for the first few miles and then it goes away.
Old Feb 3, 2013 | 11:01 AM
atombomb33's Avatar
EvoM Community Team
It sounds like it could be a few different things. Take it to the dealership and have them troubleshoot it. Make sure to stay with them for any test-driving they do when they try to recreate the problem. Here's a few options of what it might be.
1) The tires developed "flat spots" from sitting too long, but I'm not sure since you said the car was delivered to the dealership on 1/29 and you picked it up yesterday. It's not likely, but that could be the case. If it is flat spots and they don't go away with some regular driving (typically they do unless the flat spots are really bad), you'll need to ask the dealership to replace the tires on their dime.
2) The tires might not be balanced correctly on the wheels and a simple dismount of the tires and remount/balance would solve this. Have them check the little wheel weights at the same time. Some of them may have fallen off at some point. The dealership would also need to take care of this out of their pocket.
If it's not one of those things, then it could possibly be suspension related, but I think that's unlikely.
If you don't have any luck with the dealership, I'd be happy to take a ride with you (I'm up in Westchester County) to get a feel for what it might be.
Old Feb 3, 2013 | 11:47 AM
love9sick's Avatar
It's hard to tell if it's a problem because I don't know how hard it's doing it for you. The car normally will be a little rough on the suspension when not completely warmed up suspension components are taken on the highway, but never to the point where my hands go numb.
Old Feb 4, 2013 | 07:58 PM
maldito_17's Avatar
wheel balance and align is the best solution...
Old Feb 8, 2013 | 12:45 PM
Zro2Hero's Avatar
As stated above, wheel balance/alignment or it could be as simple as tightening the bolts down on the rims, previous owner of my car didn't fully tighten the rims onto the hub so it was vibrating against that
Old Feb 8, 2013 | 08:44 PM
FastAttack's Avatar
brand new car
like i said on my post take it back to the stealership let them fix it.. once they do never look back and return lol
slicksta69
15
Jun 20, 2016 09:23 AM
AlexDRS94
Apr 14, 2015 04:37 AM
adolfo415
Jun 29, 2013 01:21 PM
revolution12
Jun 18, 2013 11:33 PM
EndlessRed
Feb 10, 2009 08:38 PM
