Sponsored by:
Sponsored by: CARiD
price for 400hp??
Old Jan 15, 2014 | 11:43 AM
  #31
Uscbryan's Avatar
Originally Posted by kosteniuks17
So what differences in hp would you see between E-85 and 93 octane. AKA same setup and same bolt ons, fuel pump, etc. Im guessing 20-40 hp difference? And is there truly a way you can switch back and forth between the two?
I went from about 335hp on 91 to 397hp on E85. Same dyno. So about 62hp gain. Not sure the hp difference between 91 and 93 but I wouldn't think its 30hp.
Yea you can switch. I just hold the cruise control for 10 sec. But I have not gone back to 91 since I got E85. Makes no sense. Purpose is more hp not less. But it's nice to have the option if I ever get stuck out someplace with no E. But I usually plan trips around E stations and carry a VP can that holds about 6 gallons.
I can go about 200 miles before getting the flashing fuel light. I have made it 30 miles with the gauge showing empty. It will go more but not sure how much more.
Old Jan 18, 2014 | 08:03 AM
  #32
evox_gsr_kid's Avatar
i have intake turboback , upper and lower intercooler pipes, ams intercooler, and on tuned on e85 doing 402 whp
Old Jan 20, 2014 | 10:39 AM
  #33
ETS Michael's Avatar
I don't think pushing the stock turbocharger to 400hp at the wheels is going to be your most reliable option. The factory turbocharger is not designed to be ran at that horsepower level. I would recommend looking at a turbo kit option. It looks expensive at first when comparing pricing. But everything that comes with the kit makes it worth it.
We put down 440whp @ 18 psi using a 35R turbocharger. The 30R setup will spool up faster (3500-3800rpm) and put down similar power at low boost. The garrett turbochargers are ball bearing and dead reliable at this boost range. Intake air temps will be much lower than a stock frame turbocharger.
I would highly recommend looking at a turbo kit if you plan on pushing 400whp+
http://www.extremeturbosystems.com/E...-X-Turbo-Kits/
Thanks,
Michael
Old Jan 21, 2014 | 12:44 PM
  #34
RCL's Avatar
RCL
yeah 3k should get you around 360whp np
Old Jan 23, 2014 | 04:42 PM
  #35
lippy1306's Avatar
Originally Posted by r3volution
the supporting mods above (full exhaust, intake, intercooler, boost controller, injectors) + mhi turbo upgrade ($1,700ish). Factory mitsu turbo with 400+whp potential retaining factory spool characteristics.
+1
Old Jan 25, 2014 | 11:02 AM
  #36
OffsetZ33's Avatar
Man I wish I had access to E85... Some good extra power to be had
Old Jan 25, 2014 | 11:17 PM
  #37
u4styx's Avatar
there is meth injection too
tweakdsm
Jun 6, 2017 07:28 AM
Black_EVO_MR
Oct 18, 2014 06:23 PM
Boostfiend
Apr 24, 2013 03:06 AM
moevo9
42
Oct 26, 2012 01:58 PM
lttldggr
16
Aug 9, 2009 04:02 PM
