Evo X mileage check ver. 2014
OEM wouldn't do that
2008 GSR
82,000
AMS intake, turboXS widemouth DP, test pipe, Tsudo 3" cat-back, GS 3-port, UICP, Synapse BOV
Issues: I'm on my 4th clutch, ACD pump replaced (warranty), Some transfer case and drive shaft issues due to lubrication issues.
82,000
Yeah, someone stole my car, totalled it, had it fixed and repainted it all while I was sleeping one night. I've owned the car since it had 32 miles on it.
You obviously don't know what the sun is like down in southern NM and how fast it can destroy paint, especially the horrible paint Mitsubishi uses.
Issues I had during my 100k tenure:
-clutch needed @ 41k (car was making 350awhp on E85/stock turbo)
-motor blew at 42k (bad tune, boosted 36psi and put a rod thru the block)
-CMC failed at around 65k (before they issued the recall, OFC)
-ACD pump failed at around 70k
-motor #2 popped just after 100k (this I have no idea why- had just fixed a couple of exhaust leaks to get fuel trims back in line, car was running great for about a week- confirmed by wbo2 and data logs. the only problem was an apparent faulty IAT that read about 40* lower than the actual temp. not sure if this could have caused it to pop, but it is the only issue I was aware of)
2014 PB GSR SL
120 miles
Stock (for now)
Possible leak in the sunroof seal/gasket? We had some freezing rain last night, and I noticed some water droplets around my console/shifter area when I got in the car this morning. Investigating further once we have more precipitation...
120 miles
Stock (for now)
2014 WW GSR w/ handling package
Mileage: 3,000km
This car is my daily driver and has given me no problems so far. In regards to the transmission being a little stiff/tight for a new car, it is completely normal. My Evo X is shifting like butter in all gears now. It was a little stiff when brand new but is really smooth now.
This is normal as the syncros and hub/sliders wear against each other. I have built countless DSM and Mitsubishi transmissions (race and stock specs) for a lot of the guys here in Canada, and every new transmission I build can be a little tight until broken in for atleast 1,000 kms
Mileage: 3,000km
2014 PB GSR 2,220 Miles Drop in K&N Filter, 18x8 30mm offset rims with Hankook snows Changed out awful dim stock headlight bulbs ECU recall to address idle other than that nothing out of the ordinary
