Sponsored by:
Sponsored by: CARiD
Airbag light stays on.. Help
Old Jul 16, 2014 | 02:41 PM
mr2dsm's Avatar
I recently swapped out my factory seats for a different set and it caused my airbag light to stay on.. Now I put the factory Recaros back in and the light still stays on.. I tried resetting by disconnecting the battery for 12 hrs ... But the light is still on.. Anyway to get this reset without going to the dealer? It's a 14 GSR.. Thx
Old Jul 16, 2014 | 08:05 PM
Iowa999's Avatar
Too bad you didn't read up on this before doing the work. You have lost the calibration of the weight-sensors in the passenger seat. No-one that I know of has come up with any alternative to going to a dealer and having them do the recalibration.
Old Jul 17, 2014 | 03:15 AM
mr2dsm's Avatar
Thank you for the information Iowa.... Appreciate the post..
Old Jul 17, 2014 | 08:26 AM
Iowa999's Avatar
You're welcome.
Someone really needs to come up with a reliable method of defeating the weight-sensors on the passenger seat. Even if you had disconnected the battery while moving stuff around, as soon as you try to drive with an aftermarket passenger seat, the SRS system will fail.
Old Jul 17, 2014 | 08:29 AM
sgtr275's Avatar
As long as the original sensors are back in the car and plugged in, the light should go off. I would check all of your connections.
Old Jul 17, 2014 | 09:04 AM
mr2dsm's Avatar
Yea, I wish that was true... But all connections have been checked multiple times and everything is connected.. Maybe another reason might be that I loosened and retightened one of the weight sensors while the seats was out of the car.. At this point I just don't know.. I scheduled the dealer to fix my blunder.
Old Jul 17, 2014 | 09:18 AM
sgtr275's Avatar
Possibly. I forgot to swap the sensors when I swapped seats and once I corrected the mistake, my light turned off.
Old Jul 17, 2014 | 04:20 PM
mr2dsm's Avatar
Well I went ahead and checked all connectors one last time and guess what I found... The one black connector under the driver seat wasn't pushed on all the way.. So I reset everything again by disconnecting the battery and the light is gone!! So freakin happy!! Thanks to both if you for your comments.. Much appreciated guys!
Old Jul 17, 2014 | 07:43 PM
sgtr275's Avatar
Good deal!
Old Jul 25, 2014 | 08:16 AM
Uscbryan's Avatar
Funny thing is I have aftermarket seats and the airbag light went over after a month or so. Now it will randomly come on for a few seconds every month or so. But I don't care anymore. I have the Tire pressure sensors warming on 24/7 and the check engine light every once in awhile. More lights just make the dash more colorful.
Old Jul 25, 2014 | 10:41 AM
sgtr275's Avatar
The passenger seat weight sensors may need calibration if your new seat is significantly different in weight from the stock seat.
Old Aug 3, 2014 | 08:59 PM
LB_Reddy's Avatar
Check all connects.the pass seat has a small harness that plug into cpu..on da dash..it might be loose.dats why u getting dat seat belt lights.
Old Aug 4, 2014 | 08:55 AM
Veronica's Avatar
(OP already fixed it..)
gvtwest
Nov 14, 2017 04:19 PM
Eclipse10358
Lancer Troubleshooting
Aug 6, 2014 05:49 AM
fyreant
May 30, 2014 06:34 PM
StevenStarke
Jun 15, 2012 04:53 PM
quikkstylez
Aug 11, 2005 03:10 PM
