Sponsored by:
Sponsored by: CARiD
How do you reset the driver's window?
Old Apr 20, 2015 | 07:14 PM
Pargy's Avatar
My driver's window is messed up, the auto roll up/down doesn't work and the window stops 3 times when I roll it up. I have to let go of the stitch and pull it up again to get it all the way up.
I've tried a ****load of times/ways to reset it but I can't get it to work.
I've read that you need to roll the window down and hold the switch for a few seconds, then roll it up without stopping and do the same. The problem with this is the window stops 1/3rd of the way up every time. I've also tried it the opposite way, starting at the top, and that doesn't work either.
Am i just doing it wrong?
Old Apr 21, 2015 | 06:46 PM
MercuryMR's Avatar
roll & hold the window button until the window rolls all the way down and keep holding the button for about 10 seconds or until you hear a click, then repeat the process when rolling the window all the way up and hold the button for ten seconds or until you hear a click, then release. This should fix the problem with the short-stroke of your window.
__________________ or check a manual this happened to me before I think this will work.
Old May 10, 2023 | 07:27 PM
redbackLahiru's Avatar
Smile
i have the same issue.my Passenger/Assistant side won't rolled up. same like yours it moving 1/4 and stop. did you get you slove the issue?
cymdiggity
Lancer Troubleshooting
13
May 19, 2023 07:41 PM
Gsr08
Aug 15, 2013 05:36 PM
kevinRR
Feb 18, 2013 09:38 AM
KJS
May 16, 2012 05:10 PM
dmun505
Aug 18, 2010 06:27 PM
