Sponsored by:
Sponsored by: CARiD
DDM HID Kit help please.
Old Dec 15, 2015 | 03:08 PM
hoobastnk90's Avatar
Ill have to check it out when I get home my work blocks that page. But I bought the the Morimoto Xb kit I think that's what it was called and it was for my wifes 2013 accord. It had really good write up for it but the relay thing is pretty easy. Ill try and take a picture of the light color when I get home later tonight
Old Dec 15, 2015 | 03:32 PM
CaptainCrunch's Avatar
Very cool. Thank you! Its weird to me that two different sites are saying I don't need a relay.
Old Dec 15, 2015 | 04:12 PM
I did two pics of the accord and one pic of the evo with factory hids for reference.
Attached Thumbnails DDM HID Kit help please.-accord.jpg   DDM HID Kit help please.-accord-2.jpg   DDM HID Kit help please.-evo.jpg
Old Dec 15, 2015 | 04:23 PM
Also they have a video of the install process I noticed so it pretty much lays it all out for you.
Old Dec 15, 2015 | 05:25 PM
Thanks for the pics!!! Coming through in the clutch! Appreciate that. Now I have to do this mod. lol
Where did you find a video?? I looked everywhere.
Old Dec 15, 2015 | 06:48 PM
Old Dec 16, 2015 | 04:08 AM
Thanks hoobastnk90! Going to contact them too, about the harness relay.
Old Dec 16, 2015 | 08:10 AM
02modlanceroz's Avatar
Retrofit source is the way to go. It's the expensive route, but it would turn out so much nicer to put projectors in. Most people buy the depo projectors and replace the projector with the Evo XR
Old Dec 16, 2015 | 09:11 AM
Veronica's Avatar
My input (see below)
Originally Posted by CaptainCrunch
Thanks so much, Veronica! Great info.
2. I looked around, and there is no mentioning of needing to ground the system. Is that an oversight?? You need to ensure when you mount both ballast that each one is screw or bolt mounted to chassis ground (or run separate wire from the case to a good ground). This completes the Farady Cage that keeps the Electro-magnetic force from emitting and ruining your radio reception.
3. No DRL's. I have a 2015 and never had them. Ah! Then you should not need a relay! The relay was to keep DRL 'sine wave' voltage from causing a flickering. The 35W system is fine using the existing wiring. Just plug the ballast into the original lightbulb wiring and the output to the new HID bulb.
You really can do this yourself - and if you get stuck - we are here! Send pix before turning the lights on if you need to...
Old Dec 16, 2015 | 09:26 AM
Veronica's Avatar
And for the flash/hot strike:
4. I heard that a long time ago, like in the year 2000. I thought that was a myth. Good to know! Thank you! Well, they do for me - they may not for you if you don't use a relay (no DRL). Let us know!
Old Dec 16, 2015 | 10:40 AM
Thanks so much Veronica! Sounds like no relay needed, but should ground to avoid radio signal issues? This makes me feel better..again. lol. I looked under the hood, looks as though its a tight squeeze. Finding a ground though is gonna be..
Old Dec 16, 2015 | 11:04 AM
Man there is a ton of things to be able to ground it too under the hood! I see your in NJ there has got to be some evo shops around there that could help ya if your not comfortable.
Old Dec 16, 2015 | 11:44 AM
03evo8racer's Avatar
Using a kitfrom the retrofit source in my head lights and my fogs and worth every dollar. Don't just put them in the halogen headlights either you will blind people. You will need to do a retofit to put the projectors in so they don't blind people. My as well do it right.
The DDM kits are decent but I know a guy who has had a problem with lights going out all the time. So I didn't go that route even though other people have had good reviews.
Old Dec 17, 2015 | 06:01 PM
Tucci_973's Avatar
Originally Posted by TxFAkuma
Hey man, i asked these questions before.. I was going to do the DDM tuning kit but i got scared and backed out lol. I don't really want attempt any of this by myself and i just never got around asking a shop to install them for me because of other projects on the car. Now, i WAS going to get the DDM kit but then i heard of another website that MAY have a better plug and play set up.. But first let me give ya the info you need for the DDM kit.
You need to do a retrofit = LINK - https://www.evolutionm.net/forums/ev...eadlights.html
Duel in, duel out
Error eliminator
Adapter cables
This is the link to the questions and answers in my thread = https://www.evolutionm.net/forums/ev...-kit-help.html
Now, i said their might be a better choice instead of DDM tuning. It is at http://www.carxenonhidkits.com
I have not had any experience with kit but their was a user on here that said he installed HID kits from http://www.carxenonhidkits.com on 3 of his cars over the years and they were excellent!
I myself have not had the courage to try them... yet. I'm undecided on what route i should take to get these wacked halogen lights out. I would buy a entire HID housing but they are very expensive...
That was me I'm installing mine from carxenonhids.com next Saturday along with a bunch of other stuff maybe I'll make a quick dyi and show what it came with
Old Dec 17, 2015 | 06:03 PM
Tucci_973's Avatar
Hi. Spent the last good while reading over aftermarket HIDs for us halogen guys. I wanted to get an HID kit and hear DDM tuning's one is very popular.
Is this configuration correct?:
35 watt
9006 bulb
color: 4300k
mounting bracket: 35w ballasts
and then don't need the Harness, Eliminator, or adapter cables???
Price is only $29.94??? Do I need anything else??
Thanks sooo much!!
Where are you in nj if you're anywhere near Essex county and want to come chill at the shop and see the install and results let me know
