Sponsored by:
Sponsored by: CARiD
Failed smog with e85...
Old Mar 26, 2016 | 07:45 AM
SpeedI2acerX's Avatar
Originally Posted by razorlab
So, did you check your fuel trims or should I suggest it three more times? One of them will be more than +/- 12.
Dash command can show you the trims, no need for evoscan if you don't have it.
I'm looking thru the dash command app and I don't see a fuel trim section. Do I have to add the New gauge stern?
Old Mar 26, 2016 | 10:42 AM
RazorLab's Avatar
It will be in the OBD-II PID area. Short Term Fuel Trim, Long Term Fuel Trim
Old Mar 27, 2016 | 07:01 PM
found it. its just a little digital gauge that sweeps left to right. i dont see anything unusual. it stays at 0 on idle but doesnt go pass -10/+10
so i decided to put my test pipe back and move the o2 sensor towards the back and move the a/f sensor to the front. so far the code hasnt pop up but i can see it "pending". when i had it the other way around it popped up within 10 miles.
Old Mar 27, 2016 | 10:49 PM
LetsGetThisDone's Avatar
found it. its just a little digital gauge that sweeps left to right. i dont see anything unusual. it stays at 0 on idle but doesnt go pass -10/+10so i decided to put my test pipe back and move the o2 sensor towards the back and move the a/f sensor to the front. so far the code hasnt pop up but i can see it "pending". when i had it the other way around it popped up within 10 miles.
Which sensor is where? The sensor that the ECU uses for fuel trims NEEDS to be in the down pipe. It cannot be after the cat or it won't work. You shouldn't be moving sensors around.
Old Mar 28, 2016 | 06:56 AM
No I have a test pipe with 2 bungs. I just swap the 2 NOT the one on the down pipe.
Old Mar 28, 2016 | 07:37 AM
RazorLab's Avatar
I don't think you are looking at the correct PIDS. The CEL you are getting is from fuel trims being out of spec.
I think you should take your car to your tuner and see what they think.
It's hard to diagnose over the internets.
Old Mar 28, 2016 | 07:51 AM
I got appointment today at RRE so hopefully it's something simple as a bad tune. I'll keep you guys posted.
Old Mar 31, 2016 | 11:38 AM
So a little update: I was finally able to pass smog! After a long drive and a nice tune from Road Race the codes finally came up "ready". The guy at the smog place gave some tips. I almost fail the visual the second time even though i didnt change much. During the tune i decided to take off my mb controller and have a 3 port put in, thats a no-no and apparently you cant have a ethanol analyzer? lol the tech was cool though he just told me to put everything back to stock as possible for my next smog..in 2 years.
Old Apr 1, 2016 | 06:49 AM
hoobastnk90's Avatar
man cali suxs... sheesh well glad you got it to pass!
Old Apr 2, 2016 | 11:07 AM
hydro334's Avatar
Do you have an open element intake? I haven't had to smog my Evo but I doubt they'll notice my GM 3-port.
Old Apr 2, 2016 | 01:40 PM
I have an AEM intake with the lid close. He wrote that I have a carb sticker for it. If the techs **** he'll know what you did with the fuel and intake lines. I was surprise he didn't get he for just having a Boost gauge.
CDrinkH2O
14
Oct 9, 2011 11:22 PM
4g94T
E85 / Ethanol
Aug 17, 2011 10:57 PM
ultimatesteve
E85 / Ethanol
Aug 22, 2008 04:59 PM
Gonzo314
Jul 3, 2006 05:24 PM
