Sponsored by:
Sponsored by: CARiD
Stock Clutch Failed at 3400 miles
Old Nov 11, 2016 | 08:35 PM
  #31
Robevo RS's Avatar
The clutch pill does not make the car unfriendly to being launched. Even with the pill in there, you can side step the clutch and shock the f#ck out of the drivetrain. That pill makes the car easier to drive normally by making clutch engagement easier to modulate when shifting and taking off normally.
The Evo can launch, its just pretty well known you're going to wear clutches out when doing. Even if you have an MR, you're going to experience premature clutch wear with repeatedly launching the car.
The GSR has a two step (stationary) rev limiter from the factory, its at like 5000rpm I think.
The drivetrain can handle proper launching (proper amount of clutch slippage to avoid shocking the driveline, and avoiding wheel hop are the main concerns). In the X, you'll explode the rear diff in a higher power car, but that is solved with doing the ct9a rear diff swap.
Launching is still hard on parts, no matter what car you have. So expected repeated launch to decrease the life of certain parts. 1st gear, transmission input shaft bearings, clutch, and even the diff and tcase. But if you're doing it right, you're not going to have catastrophic failures every 3500 miles.
not even 45K, still on stock clutch
With 275 tires and tuned
I did changed though in the car the CMC and removed the clutch pill .
(the CMC is a AMS clutch kit)
And the CT9A chassis rear just as fragile as a CZ4A
Old Nov 18, 2016 | 08:09 AM
  #32
DeweyD's Avatar
Originally Posted by Napalm_Enema
If so, just enjoy but this is more of an autocross car than a 1/4 mile car imo.
I would just like to point out that in most autocrosses you want to be launching the car as well, or at least I do it all the time.
Old Nov 21, 2016 | 10:35 AM
  #33
Epyon's Avatar
I think it depends more on the course, some courses time starts when you leave the box, others start about 10-20 feet ahead of the box so you don't have to launch. And even if it's right out of the box you can assume most people won't launch so it's not going to set you back if you don't.
Old Nov 21, 2016 | 01:48 PM
  #34
1STI2EVOX's Avatar
I went through a clutch so fast with my first wrx when I was pretty young due to launching. The tuner that put new clutch in said he had never seen one worn so much so fast. I maybe launched it 20 times. I never launch my evo because of that.
Old Nov 22, 2016 | 11:45 AM
  #35
SagegreenX's Avatar
Evo X GSR stock clutch is so bad
Old Nov 22, 2016 | 11:52 AM
  #36
hoobastnk90's Avatar
pretty sure the driver has a lot to do with it. Sold my Evo X with 40k on the clock still on the original clutch and I must have done 6 or 7 track days on it.
Old Nov 24, 2016 | 08:57 PM
  #37
Noize's Avatar
EvoM Administrator
Don't launch. /thread
Old Nov 25, 2016 | 07:38 AM
  #38
moparfan's Avatar
What rims/offset and is it stock ride height?
Old Nov 26, 2016 | 02:38 PM
  #39
Robevo RS's Avatar
Ambit cheap wheels, with about +20 off set, and 9.5 wide. Real fenders are slightly rolled.
not stock height, lowered on Eibach Pro kit.
Old Dec 1, 2016 | 12:01 PM
  #40
BigT's Avatar
My 2015's clutch is still great 30k miles later. No launches though! :laugh:
Old Dec 1, 2016 | 01:21 PM
  #41
ChipperEvo's Avatar
wow you must drive a crap ton to put 30K miles on a 15. do you have a 3 hour commute or something?
Old Dec 12, 2016 | 06:54 AM
  #42
Nsomniac's Avatar
EvoM Administrator
OP, 3400 miles is pretty low to burn through that clutch. Mine made it 15k with 3 seasons of autocross and mild-to-strong launches to start every run. I knew I was going to want something different anyway, so I just treated it like a wear item. As others have said, and as I look back, I don't think I would have taken that approach knowing what we know about the rear end now.
Old Dec 17, 2016 | 04:49 AM
  #43
austin_davee's Avatar
My clutch started slipping at 10000 miles. I would just buy an aftermarket one and not worry about it
Old Dec 17, 2016 | 05:29 AM
  #44
Stonewall's Avatar
You launched your car ~20 times before you even broke it in. Geez.
krackerstache
72
Mar 3, 2016 06:33 AM
TOAjosh
Apr 27, 2012 07:34 PM
MR2liter
45
Oct 11, 2006 12:12 PM
dp2580
Aug 30, 2004 10:42 AM
zTargeTz
19
Oct 22, 2003 10:04 AM
